Question about Measuring Tools & Sensors
When installing molding around door or window interior does the thigh side of the molding go on the edge of the door or on the outside ?
  • 546 Answers
Thickest edge towards outside/taper towards door.
Posted on Sep 30, 2009
Testimonial: "it was very helpful thank you so much"
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Replacing quarter glass on left side on 2005 pontiac gto
Remove the door opening weather-strip. Refer to Door Opening Weatherstrip Replacement in Doors.
Remove side sill trim plate. Refer to Door Sill Plate Replacement in Interior Trim.
Remove the lower quarter panel trim. Refer to Rear Quarter Trim Panel Replacement in Interior Trim.
Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement in Interior Trim.
Remove the quarter upper trim panel. Refer to Rear Quarter Upper Trim Panel Replacement in Interior Trim.
Remove the center pillar outer applique. Refer to Center Pillar Applique Replacement in Exterior Trim.
Remove the roof drip molding. Refer to Body Side Roof Drip Molding Replacement in Exterior Trim.
Important: It is necessary to use new nuts when reinstalling the quarter window.
Remove the nine quarter window nuts (1), securing the quarter window assembly (2) to the body opening.
Caution: When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Important: When removing the quarter window from the body opening make sure that the attaching pins are clear of the outer body.
Remove the quarter window (2) from the body opening.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement in Seats.
Remove the rear seat back. Refer to Rear Seat Back Replacement in Seats.
Remove the door sill plate. Refer to Door Sill Plate Replacement .
Remove the 3 quarter trim panel retaining screws (1).
Starting at the lower edge of the trim panel and moving alternately clockwise and counterclockwise, pull outward on the trim panel to disengage the eight rear quarter trim panel attaching clips (2).
Remove the quarter trim panel from the vehicle.
Remove the 4 radio speaker grille speed clips (1), securing the speaker grille.
Remove the speaker grille (2).
Remove the rear quarter trim panel insulator (1), from the back of the quarter trim assembly (2).
Remove 7 rear quarter trim panel armrest retaining clips (1).
Remove 7 rear quarter trim panel armrest retaining nuts (2).
Gently pry the quarter trim panel armrest insert assembly (3), away from the rear quarter trim panel and remove.
You mite look for a video on youtube !
Dec 23, 2016 | Pontiac Cars & Trucks
Removing rear interior panals
Remove one Phillips screw from leading edge of door panel (near latch). Remove small cap behind the door handle, inside another Phillips screw - remove screw and then the cup behind the handle. Look down in arm rest and there is another Phillips screw. Last screw is behind the approximately 1 1/2 inch plug on front upper corner of panel. At this point, gently pry around lower edge and sides - there are either five or six clips pressed into the door frame. Once all are disengaged, gently swing the bottom of the panel out and lift off the top edge of door next to window opening. Once panel is off door, gently remove the control plug from the door lock/window control on the rear of panel. Install in reverse order
hope this helps
May 04, 2013 | 2005 Mazda Tribute
How do I take the door panels off
the interior door panels? for the most part the panels are of simple design, they sorta just 'pop' on and off, they are held on with plastic screws attached thru the metal interior of the door. start with the end closest to the outside edge of the door and with a plastic 'pop tool' (i forget the exact name for them but they are for removing headlights and skid plate bolts without damaging metal) or even a flat head screw driver with a folded shop towel over the edge to prevent damage to either panel, gently work under the panel all along the side. it should work loose in short order without much fuss, from there you can see the other panel screws and work around handles/manual window cranks.
Feb 07, 2012 | 1998 Chevrolet Cavalier
I have noticed blue mold in my basement coming from behind the area that has wood paneling, but also around the entire edge of the floor even where the walls are concrete (both interior and exterior...
This mold is from dampness in the basement.
Often this is a result of no vapor barrier installed when the insulation is put into the walls. Moisture is allowed to seep through the walls and gets into anything, even concrete.
The other problem may be from a lack of weeping tiles outside the house.
When the contractor formed the foundation walls, he was supposed to install weeping tiles to keep moisture out from outside.
Most older houses don't have this, and I'm seeing it more and more.
I would advise contacting a general contractor and getting some advice from them. You may have to have weeping tiles installed, which consists of tearing up the ground around the foundation to do so.
Then you may have to remove the flooring and wall panels as well as the drywall to install a vapor barrier.
Good luck.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Sep 22, 2011 | Computers & Internet
How do you get the driver's door latch out past the window guide?
Remove all screws around the outer edge of the door panel. Carefully pry off the decorative cover behind the door handle and remove the torix screw. Lift up firmly on the door panel to remove. To reinstall, line up molded plastic hooks on back of door panel with notches in the door, push down to secure, reinstall torix screw, decorative cover and screws.
Also before you lift away the panel, you'll need to undo the electrical connectors for the power window and door locks
It is best to get the whole power window regulator assembly from the junkyard, which includes the power window motor. Cost should be no more than $40. Remove interior door trim panel by removing all screws and pulling up on the door panel. Unbolt existing window regulator assembly and slide guides from aluminum window track (you will have to uncrimp one end of track). Installation is the reverse of removal (remember to recrimp aluminum window track after reassembly). I did this repair in 45 minutes, power window worked like new. Good Luck!
Dec 12, 2010 | 1996 Chevrolet Monte Carlo
How do you install the drivers side window in a 1994 Jeep Cherokee Sport? Already removed interior door panel, bottom window molding, and screw & washer from regulator, Can't understand how to get...
Most door glass slides in from the top **** in the door. Sometimes the window seal around the window frame may have to come out and can be re-installed after you secure the glass to the track. You may have to insert the glass at an odd angle to fit it thru. Be sure to have the door panel off so you can access the track screws(bolts) and make sure you do or don't have to bond it with adhisive. A great bonding agent for this is gorilla glue, tested and still working on my friends 93grand cherokee. Good luck.
Aug 31, 2010 | 1994 Jeep Cherokee
How do you remove interior door handle form 1993 Ford Tercer The window won't roll up and I can't get the handle off to get the panel off to get to the window tract
It's easy!
  1. Remove triangle-shaped plastic cover Fwd of door window - gently pry it off
  2. Remove screw from the plastic cover behind door open lever
  3. Remove door lock plunger. (unscrew)
  4. Remove screws down inside the door pull hand-hold area
  5. Look for other phillips screws - sometimes around the lower 1/2
  6. Pry hidden plastic hold down fasteners from around the edge - pull the panel away from the door and where you see it 'stuck' to the door, slide a pry tool, a stiff putty knife works well, up in that area and pop the fastener off.
  7. Lift door liner enough to get to the mirror power connector and unplug.
  8. For some model years, with door panel loose, you can access the bolts / screws that hold the interior trim piece in place and remove.
  9. Remove Mylar cover for access to 3 Mirror mount studs, speaker screws, door lock actuators, window motors, etc.
  10. Remove nuts, (hold the mirror up from outside) and remove mirror. (Feed electrical harness through door openings as required to facilitate removal.
  11. Reverse order for installation.
Jun 01, 2010 | 1993 Ford Taurus
How do i install body welt (molding around driver's side door)
if youre talking about the rubber that seals the door to the car when its closed, you just push that ****** on, and it slides neatly into place. its pretty straightforward. Sometimes it can be a pain to get to stay in place, but after a few days, it shoul conform to the plastic interior panels and stay in place.
is that what you were talking about?
Oct 13, 2009 | 2002 Nissan Maxima
Measuring Tools & Sensors Logo
29 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
