Model 5500w wont spin or aggitate,motor turns in spin cycle but drum doesnt spin
  • wblee3 Sep 30, 2009
    no belt is on and turns good, tub just wont spin
  • wblee3 Oct 01, 2009
    the belt is on the motor and the motor spins fine unless there is a belt on drum inside machine casing ..but thanks any way
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Has belt fallen off..?
Posted on Sep 30, 2009
  • Gerry Harvey
    Gerry Harvey Oct 01, 2009
    Sounds like motor perhaps check brushes within it/
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
My kenmore clothes washer won't empty water
some models reverse the moter to activate the pump .. some have a solonoid to engage the pump .. depends on what model you have ... if the motor runs but still it doesnt pump then look for a broken belt that drives the pump .. on some there is a little universal joint that sometimes breaks .. often the pump becomes clogged with coins and other debree .. you didnt say if the spin cycle started or not .. if it doesnt then you could have a bad door switch .. if that doesnt operate then the spin cycle wont start and it wont drain as well .. you can test for clogs by taking the drain hose out and placing it on the floor .. if a lot of water comes out then its not clogged .. if no water comes out then you have a clog .. (be prepaired for lots of water) .. even if water comes out there still could be a coin stoping rotation of the pump .. there is no reset on the pump, it is almost always run by the main motor ..
Sep 12, 2009 | Kenmore Washing Machines
No motor action, No aggitate or spin cy cycle
try turnin it off and wait 20 seconds and turn it back on. That is how I get mine to unlock
Aug 29, 2009 | GE WDSR2080D Top Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Danby front load washer Will not spin motor runs
If the "Spinning Off" button is pushed in you will get this problem.
It happened to my wife last week.
If the drum is turning the belt is OK
Jan 25, 2009 | Danby DWM5500 Front Load Washer
WONT SPIN AT ALL
Is there water left in drum, and does it aggitate.
Oct 20, 2008 | Kenmore 23822 Top Load Washer
Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Jul 20, 2008 | Fisher and Paykel IWL12 Top Load Washer
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
