Question about Vacuums
Halo main suction motor will not come on
Suction motor will not come on, tested with cover off????
Used my Steam Vac twice and now there is no suction where the unit should be picking up the water layed down from the sprayer. I've readjusted the collection tank, took the lid off and made sure the side clips were snug and cliped against the tank, but still no suction. I don't hear any unusual noises, the handle lays down, water spits out, it just has lost suction. Any suggestions? With Appreciation, -kb
Posted on Sep 30, 2009
No suction motor comes on at all
It should be under warranty. Take it to a warranty repair center
Jan 17, 2014 | Kenmore 31913 Progressive Direct Drive...
Electrolux cyclone power 1900w no suction with main attachment
If you've tried several different attachments and they all exhibit the same poor suction problems, you should completely check the parts of the vac that are common to all the parts that have the problem.
Since the motor creates good suction without attachments, I suspect the problem is the hose. Either an obstruction or a crack. Typically, if you block the end of the hose, the pitch of the motor's sound will go up slightly - like it it is spinning faster (it is). You can keep removing parts from the vac intake until the motors sound decreases - and that will indicate the part that has the obstruction. If it is a hose, you should clear the obstruction with a "snake" or other object like a pole.
If the motor sound does not change, then there is likely a split or crack somewhere between the intake of the vac and the device. You'll have to check it carefully - or if possible - connect it to the output of a vac and seal / cover the end. Feel along the length of the hose, etc. for air being blown out. Repair the opening and you should be "good to go"
May 12, 2012 | Electrolux Vacuums
Why has air suction pressure has dropped off to almost no suction? Filter cleaning did not help.
Do any of the ports have greater suction than others and are they closer to the vacuum motor unit? You appear to have a piping clog and locating it's position is the primary problem. If you have a portable vacuum, try placing it's hose in the exhaust port of the main unit and insert the pickup hose in a wall port near the main vacuum so that both units are on. The combined suction may pull the clog loose and draw it into the filter of the main unit. The other remedy is to remove the piping from the main unit and see if suction is good at that point, then work your way out to the nearest wall port. Hope some of this helps!
May 24, 2010 | Electrolux Central Vacuum
Filtex central vacuum
Check suction at main unit. If it is not good and the unit is empty you might need a new motor. If good there and one of the inlets is open, connect and disconnect the main line at the main unit. If it labors each time the line is connected, there is an obstruction in the line. If it doesn't labor you have a leak in your line.
Give me feed back.
Jun 26, 2009 | Electrolux Centralux Vacuum
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Low suction
Replacing the motor cover solved the problem, it must have been warped and was letting suction out thru it.
Jan 03, 2008 | Vacuums
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
94 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
