Question about Acer Computers & Internet
Acer aspire 5920 will not start up will turn on and acer screen appears followed by a window that says windows recovery error any ideas?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You will need to reset the Laptop if it is not starting up. Follow the procedure as under to reset it---
Remove all connections to and from the laptop. Now remove the battery and press and hold the power on button for 2 minutes. Release the power on button. Slip in the battery pack. Plug in the power to the laptop and to the wall. Please do not plug in any other devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 25, 2009
I have an acer laptop 5920, when I start the machine it goes on to a windows error recovery screen. When I enter launch startup repair, the screen goes blank then returns to display the same error screen.
try to shut down the laptop completely. Remove cables and battery into it. Then press and hold power button for 8 secs. Reinsert the cables and battery back then turn it on. Contact Acer if symptom persist
Oct 14, 2011 | Acer Aspire 5920-6727 Notebook
My acer aspire 5920 boots then goes to a black
The hard disk has died. Replace it and reinstall Windows.
Apr 06, 2010 | Acer Aspire 5920-6335 Laptop
My Acer Aspire 5920 won't do a recovery
BSOD is caused by hardware error or driver error. Disconnect all hardware except the basic. Motherboard, monitor, memory, hard drive. Unplug the wireless, cd/dvd drive.
Start the computer and see if the the BSOD returns. If not, one by one add components until you see the BSOD.
If you continue to see this screen without any hardware attached, then you most likely have an onboard component failing. (audio/video/memory failure)
Download and run the MS DART cd and check hardware starting with memory then hard drive.
http://www.microsoft.com/windows/enterprise/products/mdop/dart.aspx
This should determine what device is failing, except video or audio.
Jan 24, 2010 | Acer Aspire 5920-6727 Notebook
Windows vista will not load, when power is turned on, the first screen is windows error recovery with options Launch Startup Repair or Start Windows Normally, start windows normally shuts computer down
Try a recovery . If that does not work try a hard drive test . If that passes reinstall the os . If it fails look at options on how to change the harddrive .
Oct 20, 2009 | Acer Aspire 5920-6727 Notebook
Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
My Acer cannot log in the normal screen but the safe mode
Do you see the white cursor on the black background? If so, press CONTROL+ALT+DELETE keys. If the Task Manager window appears. You can start the PC from the CD/DVD and choose Startup Repair from the choices given.
Apr 19, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 Wont Boot
Try clicking the Alt button and the F10 button at the same time right after you turn the laptop on, and see if it will go into the System Recovery mode. If it will, just follow the instructions for a partial or complete system recovery.
Mar 16, 2009 | Acer Aspire 5920-6727 Notebook
Windows failed to start !...
if you had the recovery disk it would not clear the c drive it would just set it back to when you got it but the programs would still be there this computer i a,m on know had trhe same thing done to it and i was able to recover it without losing any info if you can get into bios and set it back to defaut or fail safe options you may be able to get going from there
Feb 17, 2009 | Acer Aspire 5920-6727 Notebook
I can not get my Acer Aspire 5920 to load after turning on.
Try to see if it will boot in safe mode, by pressing F8 while the laptop boots up. If it allows you to boot in safe mode, try to do a system restore when you know that laptop was working with no problems. You can do this by clicking on start>all programs>accessories>system tools>system restore and choose a date and time when you know that the laptop was working with no problems. If this does not work or you cannot boot in safe mode (be aware that everything will look big in safe mode and when the computer reboots if asked how you want to start windows, choose start windows normally), try doing a recovery. This will restore your computer to the factory default settings when you purchased it. You can do this by booting the computer, when the acer screen appears hold down the ALT key and continuously press F10, this will open the recovery manager and you can restore it from there.
I hope this helps
Jan 20, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not start up either in safe mode or normal
IF YOU DON'T NEED ANYTHING ON YOUR PC YOU CAN FORMAT IT WITH YOUR WINDOWS OR RECOVERY CD
SOUNDS LIKE YOU MAY HAVE ALREADY LOST FILES
LET ME KNOW HOW THIS WORKS
Dec 27, 2008 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
