Question about Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
I have a Toshiba E-Studio 3511. It has an error message: Check Color Toner Cartridge. I took the all color toner out and it fixed the problem. It ran for another week and then the machine asked that I put the toner back in and it indicated that I need Cyan toner. I reinstalled the toners (shook them, etc). The Cyan is not full but it is certainly not empty either. What is wrong and how do I fix it?
    New Friend:
  • 10 Answers
There is a sensor above the coloer developer unit clean it or change the sensor
Posted on Nov 06, 2009
  • formand599
    formand599 Mar 27, 2013
    Could you tell where exactly the sensor is ? I have the sam problem.
    Problem Solver:
  • 7 Answers
The gears on back off toner cartridge are faulty get new cartridge
Posted on Sep 30, 2009
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
Cd70 error code for toshiba e studio 2330c
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Mar 01, 2013 | Toshiba E-Studio 3511 Color Copier
Getting error sc 479627 toshiba e studio 3511
479627 is your meter not the error code.
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
Jan 13, 2013 | Toshiba E-Studio 3511 Color Copier
Error code cf30 in toshiba 3511 what its mean and how can fix it
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Sep 29, 2010 | Toshiba E-Studio 3511 Color Copier
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
Hi, My Toshiba E-Studio 3511 color copier has a error message of 'dispose of used toner.' Even if I followed the direction, the error message is still there and the copier can't work. Would you help me...
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Aug 11, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 3511/4511 suddenly stopped faxing
Try use the monitor button for faxing, check whether there is tone or not.
Jul 08, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 3530c estudio waste toner error message.
Your waste toner box is located inside the front cover on the far left side of the copier. There is a plastic cover that is just clipped in (no screws) and just pops off, the waste toner box just slides out from there.
Jul 06, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Feb 01, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 280
Go into 'User Functions'
In there somewhere will be an option to replace the toner, press the cyan toner symbol and open and close the front door, the 'enter button' will be able to be pressed.. press enter and you should be ok..
Oct 08, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Color Copier Logo
1,418 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
