Question about Compaq (153515-001) Touch Pad
The pointer doesnt move sometimes AT ALL
my sister was playing around with keyboard.
and now my pointer doesnt move normally!
D:
help pleasse
    President:
  • 1,187 Answers
It may be in "accessibility" mode.
Tap the touchpad five times. A message will appear. Change it to normal mode, disable accessibility option.
Posted on Sep 30, 2009
I dropped my mouse and it appears that the inside of the mouse moved and now the sensor (red light thingy) moved and thus the pointer won't move much, clicking stuff works however, How do you open the...
try cleaning the sensor reflector b4 opening the mouse(its the light thingy @ the bottom)
if it doesnt work try opening with a screwdriver,normally covered by a sticker at the bottom of the mouse
Feb 10, 2011 | Computers & Internet
Mouse moving all around
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Dec 03, 2010 | Dynex Wireless Optical Mouse
My keyboard doesnt work.I have to use an external keyboard.
Have you checked your interner keyboard in BIOS, Try turning on the system and keep tapping F2 , see if u see a diffrent screen then normal. and try playing around with the keys. if it works then it is not a problem with keyboard , but if it is then, you need to purchase a new keyboard.
Note/:- while exiting the F2 screen,.do not save any changes.
Jun 06, 2010 | Dell Latitude E5400 Laptop
Mouse does not want to move pointer, sometimes you have to shake
How far away from the usb transmitter is the mouse or do you have something blocking the signal between the two devices?
Feb 16, 2010 | Logitech Cordless Mouse
The mouse is moving around faster then I want it too. Its hoping all around.
in your controle panel find mouse settings than pointer options than pointer speed adjust setting
Jan 19, 2010 | Logitech Cordless Mouse
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Stuttering Graphics
check for the mouse pointer movement speed.... this can be located in control panel --> Mouse Options.... there check for the mouse wheel speed and decrease it ..this may help.... sometimes wireless devices doesnt have compatibilty will vista OS , this may also cause an issue..if any vista drivers exist for ur mouse install them and check ...hope this helps...
Aug 18, 2009 | Computers & Internet
Mouse pointer seems to randomly move around the screen
The problem is in the trackpoint itself, it is defective. The fix is to either disable the function of the trackpoint through software or by physically disconnecting it.
Disabling through software can be done usually through the BIOS or in the Control Panel in windows. If there is no way for you to disable it then you have to remove the keyboard and cut the connector that is coming from the trackpoint control board. Make sure that you do not cut the keyboard cable. The trackpoint cable is usually about 4 wires thick and is seperated from the thicker keyboard cable. The only other thing to do is to replace the keyboard.
Apr 03, 2009 | Dell Latitude D410 Notebook
Mouse doesnt work
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
Mar 21, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse freezes when i move it on desktop or a window.
hi, ok go into control panel,printers and other hardware-mouse -slow the pointer speed a notch at a time. this should help. good luck,glen
Jan 04, 2009 | Microsoft Wireless Optical Mouse
Computers & Internet Logo
383 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
