Question about Dell E176FP 17" LCD Monitor
Monitor Flashes Colors when system powered down
When system is shut down, the monitor flashes different colors. Full screen goes from red to green to yellow to white, etc. The monitor power button does not work, I have to pull the power cord to make it stop. If the system is powered up, all is ok. Dell warranty expired less than 1 month ago. . .of course.
  • 9 more comments
  • blinkykatie Dec 23, 2007
    It started with the monitor buttons not working...if we turned off the computer, but left the monitor on, then powered the computer back up...well, the monitor promptly turned itself off. Monitor settings in device manager were useless and had no effect on anything we were having any trouble with. No updated drivers are available.
    Pushing the on/off button on the monitor didn't work - we figured out you just had to leave the monitor power on, plug the monitor in when booting, then UNplug it, then wait a second, THEN plug it back in..and *hope* the "on" light would flash on, then off, then back on - only then was the monitor "on"...or maybe we'd have to unplug it one more time and try plugging in again.
    NOW...well, we've been performing this ridiculous ritual for quite awhile - at *least* we didn't have to do anything specific when turning it off...until...
    Last month, it started flashing the different colors when we turned off the computer but left the monitor on. Very festive, but absolutely annoying for the most part.
  • frugalfam Dec 27, 2007
    I have the exact same problem - the monitor won't shut down and just flashes colors. I've had this system for about a year and it just started. I went through the support suggestions and it doesn't help. I can't believe I already need a new monitor - can anyone help?
  • Pocha Dec 27, 2007
    I am having the exact same problem with my monitor. Please advise.....
  • LoriAG Jan 15, 2008
    Great Tip! The problem was that the burn-in mode on my monitor was turned on. I went into my monitor menu, turned it off and now everything is great! Thanks for the tip!
  • Pocha Jan 18, 2008
    I had the exact same problem...I went in and followed the steps given, and the problem is fixed!!! Thanks so much....the dell service folks and I had been e-mailing back and forth, so this saved me a lot of hassle...
  • Roger Giellis Jan 20, 2008
    I have the flashing screen problem with a Dell 5150 laptop. It starts when I power up the laptop - flashes red, green, blue, white, etc about 2 seconds each nonstop.
    The laptop can drive an external monitor just fine,
  • love12348340 Jul 24, 2008
    I have the same problem, how to turn off burn-in mode if none of the button work?
  • peter duggan Oct 06, 2008
    ? how do i access the burn in mode i have exactly the same problem
  • Anonymous Dec 04, 2008
    Mine does the same thing. and the link doesnt get me to the directions. can someone post on here?
  • Messcook Feb 12, 2009
    Same as LoriG's
  • Anonymous Apr 25, 2009
    qdo o sistema é desligado o monitor pisca alternadamente cores diferentes. o botão lig/desl não funciona.
Reset factory settings. Push the selection button (second button from the left at the bottom of the monitor, next to the AUTO button), then go the the Factory Reset by pressing the minus button. Press the selection button again, and when it asks if you want to reset say YES by using the minus button. It's a quick fix!
Posted on Apr 29, 2009
    Problem Solver:
  • 6 Answers
Go into your monitors settings and select "Factory Reset" Then go to "Factory" and you will find the burn in setting.
Posted on Feb 28, 2009
Looks like the Burn-in mode is turned on. See here:
http://www.dellcommunity.com/supportforums/board/message?board.id=dim_monitor&message.id=70187
Cecil Thomas
Posted on Jan 14, 2008
  • cthomas Jan 14, 2008
    The previous link was cut off. Here it is in two lines, copy and paste as one address:
    http://www.dellcommunity.com/supportforu...
    New Friend:
If you can find a setting for DDC/DI and turn that OFF, this could solve your problem (it did for me).
Description of the setting is included below, but put simply it allows your monitor to communicate with your computer and make adjustments.
From wiki: The Display Data Channel or DDC is a collection of digital communication protocols between a computer display and a graphics adapter that enables the display to communicate its supporteddisplay modes to the adapter and to enable the computer host to adjust monitor parameters, such as brightness and contrast.
Posted on Mar 06, 2013
Have fixed problem myself. If you have documentation CD, insert same and reset factory settings. Worked for me. Good luck. Messcook
Posted on Feb 14, 2009
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
Red, Blue, Green white flashing screen
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 04, 2017 | Acer AL2016W 20" LCD Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Monitor flashes 7 or 8 separate colors
Your monitor's inverter board is a toast you will have to replace it.. Post back if you have experience in electronics and you wanna try it yourself..
Mar 26, 2008 | Liquid Video A170E101 Monitor
Monitor not powering down
Do you mean the computer is sutting down but on the monitor showes different colors if so you might have a problem in the system you might have to reinstall you OS if the computer does shut down but the monitor stays on and flashes different colors you have to shut the monitor down manually with the power button on the monitor.
Feb 14, 2008 | Dell Dimension 3000 PC Desktop
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Dell E176FP 17" LCD Monitor Logo
11,522 people viewed this question
Alun Cox
