Question about Dewalt DC759kar heavy - duty 1/2" 18v cordless compact drill/driver kit
Which direction do you turn the screw to remove the chuck on an 18 volt DeWalt drill
  • 8,404 Answers
Generic comment ...
normally you turn it backward to what you would expect
Posted on Oct 01, 2009
I HAVE A DEWALT 511 HAMMER DRILL AND I CAN'T REMOVE THE CHUCK. COULD PLEASE ADVISE ME ON WHAT TO DO.
Open the chuck fully and look inside, there should be a screw there that has to be removed to remove the chuck in view of the fact that it is a reversable drill and the chuck cannot be screwed off like a conventional inudirectional drill.
Jul 09, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Remove dewalt chuck that is stuck
down inside the chuck head itself is a allen head screw,, it has reverse threads on it. if you have already removed this screw and the chuck is still stuck then you will need to use a small gear/pulley puller to get it to release.
(( note: if you do not have access to a puller -- stop by you local Dewalt repair shop and I am sure that they will pull the chuck off with their puller at no charge to you )).
c...
Jan 05, 2011 | Dewalt 18 Volt Compact Drill Kit
Drill chuck
I think that if you open the chuck as wide as poss there is a screw up in the inside if the chuck thinkk its a slotted head screw undo this and chuck will come off
Jul 23, 2010 | Dewalt 18 Volt Compact Drill Kit
Can the chuck be replaced on a 18v dewalt?
Hello russ_rome,
Here is the solution from the Dewalt website.
Firstly check to see if the chuck is secured with a screw, if you have a screw follow steps 1-3 else follow steps 2-3.
Step 1: Screw will have a left-hand thread and must be turned clockwise to undo it.
Step 2: Once the screw has been removed place a suitable Allen Key in the chuck and tighten the jaws.
Step 3: You should then tap the end of the Allen Key to ease the chuck off (the chuck has a conventional thread so unscrew it in an anti-clockwise direction).
Some of our high spec cordless drills will need to be serviced need to be taken to your nearest service centre to have a new chuck fitted.
Regards
Alan Hood
ami-man
UK
Jun 10, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a older Dewalt recharge drill dd991 14.4 volt I need to
The chuck retaining screw are left handed and the chuck itself is standard right hand. Let me know if I can help further
Jun 19, 2009 | Dewalt 18 Volt Compact Drill Kit
Having trouble removing keyless chuck from 18V DC759
Inside of chuck you have a screw, remove screw then tighten an big allen wrench into chuck, short side in, then hold drill and hit allen wrench with a hammer quickly, should break chuck free.
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
My chuck is stuck
Your chuck is held onto the motor shaft by a screw located inside the chuck. This screw has loosened and requires tightening. This screw has reverse threads and in order to tighten it, you need to turn the screw in the opposite direction or in oither words, in the reverse direction.
Jul 08, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC759kar heavy - duty 1/2"  18v cordless compact drill/driver kit Logo
141 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
