Question about Broan-NuTone Broan Range Hood Accessory
Broan allure II range hood
After replacing blown fuse, fan functions normally. Lights turn on, no, they are on and won't turn off. The intensity level is brightest on #3, it dims somewhat on #2, but has a flicker, there is no drop in intensity when switched to #1.
  • tdcatey Jan 17, 2009
    I replaced the fuse and now the lights work, but won't turn off or dim.
    Sergeant:
  • 288 Answers
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Posted on Dec 23, 2007
Broan Allure range hood fan will not turn off, no matter which button is pushed.
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
May 19, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Fan turns on and off since turning hood light on a few days ago
If it is a Broan, there is a delay button that was also depressed. It will turn the fans off after a few minutes. If not, then you're shorted out either in the control panel or the wiring in the range hood.
Sep 23, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
ALLURE II STOPED WORKING ??
If nothing is working Lights/Motor Nothing, Its the small transformer. Theres 2 transformers. you will see blue and yellow wires coming out of it. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Mar 20, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Random fan speeds and light levels???
I have the same issue. Have to reset the breaker to make it stop. Bet it is a bad controller (design fault).
Nov 13, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Broan Allure II
I called Broan technical support. They said that they had heard of this issue before, but that there was no recall. I suggested that it was a frequent enough problem for it to come up 3 times in 12 mo. on one website. She was underimpressed with this statistic and said that they sell millions of them. She would not disclose the name of their supplier so that I could get some information on the actual controller unit. She did not seemed as pained as I was by having to part with $130 for a new controller.
Jan 30, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone Broan Range Hood Accessory Logo
919 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
