Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
New Lawn mower cutting off after 40min of run time
I have a similar problem. I have a brand new LGT2554 Husqvarna that will cut off after the tank runs out a half gallon of gas. At which time the gas tank is completely full. When I top it back up to almost to the top of the cap it will run again until air gets in the top of the tank. I took it back to the dealer that sold it and they checked everything and said everything worked correctly on it.
Could this be inadequate venting for the gas tank creating a vacume?
  • 437 Answers
Sounds like you have found a possible solution to your problem. If the cap is not able to vent, it will create a vacuum. If this happens again, try just loosening the cap and see if the mower will run before filling it up again.
Posted on Sep 30, 2009
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
When I turn key on I get nothing. No lights , no engine hours, no nothing.
If the battery is fully charged you most likely have a blown main fuse. If you can't find it send me the model of the mower and I will try to assist you. Regards Phil.
Apr 26, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Carb blows black smoke and runs bad but run good with no air filter or with a new filter
The old filter must be clogged. So if it runs ok with a new filter do you still have a problem?
Apr 16, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The back wheels want go cause somethings locked how do i fix that?
the hydrostatic transmission has failed. about 1200 for a new one and the mower is only worth 250 running. sell the mower AS IS on eBay and buy a new one.
Mar 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Seems as though the fuel filter is getting stopped-lgt2554
Remove the gas tank and clean it out, look for signs of water and or dirt in the tank also look for a pinched fuel line between the tank and the carburetor
Sep 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Mower keeps cutting off while trying to mow or ride with blades dis engaged. It will act like it is about to cut off a few times then it finally will. Doesn't matter the throttle position( low or high)....
This might be a stripped wire somewhere, maybe a wire going to a safety switch under the seat or on the cutting deck and it is earthing against the body from time to time.
Stephen.
Jul 03, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Spark plugs gap on craftsman ridin mower
As soon as it stops, pull sparkpug wire & check for spark, probably coil.
Nov 06, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
279 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
