Question about Sony Playstation 3 (PS3) Console
Play station 3 power comes on but nothing works. You can hear that it is powered up.
It's probably not in the setting you chose for example you might be using HDMI and it might be setted for SCART, to simply change this keep hold of the power key until you hear a beap (the first one when you just press the power key) keep hold of it until you hear another beap then let go. The setting should be changed. No problem :)
Posted on Sep 30, 2009
Sony dock not working after iOS 6 update? Just says not an apple compatible product?? Any idea of an update or a fix on the way?
My wife had this problem with iPhone 4S after updating to ios6 on a Sony xdr-ds12ip docking station. Sound would play on iPhone off the docking station, but once it was docked no sound would come through the docking station speakers (docking station radio works fine, as did the iPhone before the iOS update). Fixed it by powering down both the iPhone and the docking station at the mains, gave it 2-3 minutes and then powered on the docking station and then the phone. Placed the iPhone in the docking station and voila the sound comes out of the speakers now.
Sep 29, 2012 | Audio Players & Recorders
Tip
PS3 Has no Video - Simple fix!
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
That’s it! You can play your Play Station 3 again!
on May 13, 2010 | Video Game Consoles & Games
Tip
How to change or reset PS3 Video Display Mode
on Mar 12, 2010 | Video Game Consoles & Games
My play station will not read the disc
depending on the play station you might have a defective laser for example if you hear a clicking it cant be fixed but if you don't you should by a laser cleaner disk id suggest something like this http://shop.digitalinnovations.com/CleanDr-Playstation-Laser-Lens-Cleaner/dp/B00419ZT4I?ie=UTF8&id=CleanDr%20Playstation%20Laser%20Lens%20Cleaner&field_product_site_launch_date_utc=-1y&field_availability=-1&field_browse=3219
Dec 28, 2011 | Sony PlayStation Video Game Consoles &...
Play station is hooked up on turned on (blue light) tv is on and on the right input but nothing shows up on the screen. Please help
Please try these easy steps to sort your problem out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 23, 2010 | Sony Playstation 3 (PS3) Console
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
Tv and ps3 plugged in and on. av channel shows an empty screen
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont display on the tv!!
Jun 10, 2010 | Sony PlayStation 3 40GB System
Ps3 broken
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Play station 3 displaying problem
hold down the power button when the ps3 is turned off for 5 or more secs
Dec 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
102 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
