Question about Welding Tools
I'VE GOT HI FREQ BUT NO ARC. SMILEY TOOLS MTC 160. PLASMA, STICK AND DC TIG MACHINE. I DON'T HAVE A MANUAL OR ANY INFO. THANKS
    Problem Solver:
  • 18 Answers
Its probably the torch. Turn off the hf , with the machine triggered Measure the open circuit voltage from the positive o/p socket to the negative with a multimeter set on d.c . The correct no load output voltage for the machine will be shown on the spec plate as Uo = ........and whatever the voltage is. If you get the correct voltage try another torch or try stick welding.
Posted on Oct 07, 2009
What settings do i use to arc weld.
Not sure what machine you have, but it should be DC straight (electrode negative or DCEN) and DC reverse (electrode positive or DCEP). The polarities have different characteristics. For example, if you're planning to TIG weld, you would either use DCEN or AC (if welding aluminum). For the general stick welding process, DCEP tends to give you a deeper weld. The welding rod you buy will have recommended machine polarity and amperage range settings, you should use the recommended polarity for whichever rod you're using because different rods are designed to weld under different circumstances. But, generally speaking, most welding rods for steel will work on DCEP without much trouble.
May 17, 2016 | ARC Welding Tools
Cigweld transtig 16 pi
hi saluka.
not sure if this link will have the manual but have a look.
do not go into anything thats says fixya.it will not help you much.
Cigweld transtig 16 pi User manual Google Search
Mar 23, 2014 | Thermal Dynamics Thermal Arc - W1003603 -...
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
Oct 07, 2013 | ARC Thermadyne Inverter Stick/TIG Welder...
The tig welder will arc but there is no amperage and nothing is heated up it acts l;ike there is no amperage?
Make sure you have a good ground. With high frequency you can get it to still arc but have a bad ground.
Jun 11, 2010 | Miller Hf 251D 042388 Tig Hi Freq For...
Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Oct 20, 2009 | Welding Tools
Welding Mach.front control dials are not working
go to miller .com a u will get free manual there good luck
Jun 05, 2009 | Miller Hf 251D 042388 Tig Hi Freq For...
LINDE HDA 300 TIG WELDER HIGH FREQ. PROBLEMS
The contact should have a gap .008 .
Mar 21, 2009 | Welding Tools
Bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Dec 18, 2008 | Welding Tools
Welding Tools Logo
255 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
