Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Seat pressure switch cuts off engine when I lean to one side
I need to disengage it because I need to lean uphill when mowing one section of my lawn..................How do I do this?
  • 437 Answers
As a responsible technician, I can not tell if there is a way to disconnect that switch. It was put there for a reason. If the mower tipped up and you feel off the seat, it could come down and severely hurt you. Look at your owner's manual, I believe you are suppose to cut side to side and not up and down on a hill. If it that steep maybe a self propel mower would work better.
Posted on Sep 30, 2009
  • 472 Answers
I WOULD TELL YOU HOW BUT I CANT BUT YOU CAN TAPE IT DOWN AND TEN TAKE THE TAP OFF WHEN DONE
Will a John Deere LA175 lawn tractor start without the mower attachment installed?
I wouldn't think so. I know you DO need the seat switch depressed in order to start the engine.
Oct 18, 2014 | John Deere Garden
Why does engine die when brake released or mower engaged?
The first thing I would check is to make sure the drive belt is not binding somewhere.
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
May 23, 2012 | Garden
The mower keeps cutting when mowing banking
If you are trying to say the mower stops cutting when you are mowing a bank, that is because the **** switch in the seat is telling the relay that no **** is there anymore and it should hence not be running. Safety issue. You have to learn to lean whilst keeping your **** exactly on top the spot where the seat's safety switch is, tilt the seat up and you will see the wires coming from it.
Aug 19, 2011 | Garden
Compressor will only build pressure to 75 lbs. and won't shut off.
hi! there, the setting of your pressure switch has the ability to control the cut in and cut out of your compressor.unplug the compressor check the pressure switch by opening the cover loosening the bolt nut at the top cover you can see the four set of contactor inside crack the contactor if disengaging to the other side there should be a disengaging of contactor to cut the power supply if defective replace,if it is functioning normally.if it is not defective set this to what you want operating pressure and observe the cut out pressure several times is needed follow the pressure switch adjustment procedure.have a nice day and fix my rate,thanks a lot.
Apr 20, 2010 | Campbell Hausfeld No.FP2028 Gal Pancake...
Cub lt1045 while mowing pto keeps shutting off
I found that the safety switch under my seat was the problem for me. If I had to lean when going near hedges or low hanging branches, my PTO would disengage. I removed the safety on the seat and no problems since.
Apr 19, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Engine cutting off
Depends on how it cuts off. If it gradually slows down over a few minutes or surges, it's likely the carburetor needs to be cleaned and rebuilt. But if it's an immediate cut off, it's likely to be a safety switch such as the one that shuts down the engine when you get off the seat if the mower is running. Sometimes this happens frequently to a light person who bounces on the seat when mowing.
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
77 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
