Question about Sharp Office Equipment & Supplies
Message on sharp ar501 copier. close finisher unit and finisher covers.
  • Sharp Master
  • 1,297 Answers
Check the finisher covers sensor or microswitch.or anymore mechanical components deformation.
Posted on Oct 03, 2009
It says to close the finisher unit and finisher covers, but nothing is open on the machine.
We fixed this by taking the finishing unit (tower to the left) and leaning against it so it had better contact with the rest the copier
Mar 25, 2011 | Sharp AR-M237 Copier
How can I change the toner in my sharp 2530 sharp
open front cover ,release green holder on the right,pullout developer unit add toner .
Apr 26, 2010 | Sharp AR-M237 Copier
Sharp mx2300n is telling me to close the finisher unit and finisher covers.....taken it out and put it back in again and its still saying the same thing?
If you have open and closed ALL covers then you probably have a bad door switch. Try turning the copier off (both power switches) and on again. If that doesn't work then you should call a qualified technician to look at it.
Oct 17, 2009 | Sharp MX-2300N Color Copier
Display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
May 21, 2009 | Ricoh Office Equipment & Supplies
Unit says ''close finisher unit and finisher covers''
I have the same issue. Did you ever find a resolution?
Apr 06, 2009 | Sharp Office Equipment & Supplies
Copier Error Message
Their's a sensor that the Plug from the Finisher to the copier is not read, first make sure the "Attachment Kit' thats the part where when you push the Finisher to the Copier it Locks, their is a metal tab that sticks out and hits a "Sensor" if it doesn't hit the sensor it will keep telling you attach finsiher or close cover, if it's too annoying you can remove the finisher and unplug it from the rear. On the cover thier are alos sensors that need to be activated by tabs,MAKE SURE these are not missing if you do you need to order these items from "Koycera-Mita" Check those sensors
Mar 04, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Solution for "CH" code given by the copier Sharp SF2022
Hello sir; CH code means somewhere the door open , it seems like right hand side door did not close right.
Feb 13, 2009 | Sharp AL 1631 Copier
Finisher is not Closed
There can only be two things wrong, one is the interlock and the other is the wiring harness that connects to the copier.
Dec 04, 2008 | Panasonic Workio DP-2500E Copier
270 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
