Question about Gateway MX8711 Notebook
Battery Charging Gateway MX8711
Getting a battery red light when the computer is off - battery wont' charge and computer won't turn on.
Thanks,
Ron
    New Friend:
I have a Gateway MX8711 laptop and it would not turn on. Before disposing of the laptop, I decided to try a fully charged battery from another MX8711 laptop to see if it would turn on and it did. The battery would not charge as it lost charge. I took the hard drive out of it and was going to sell the laptop for parts. After taking the hard drive out, I decided to turn on the laptop for pictures. I pressed the F2 button as it was powering on and it booted to bios. I wanted prospective buyers to see that the lcd was fine. When I did that, I went from screen to screen to look at settings. I noticed that there was "SMART Battery Auto-Learning" and wondered what it was and so I enabled it to see what it was. It sensed the battery, knew exactly what size battery it was and everything. It started charging the battery that would not charge and went through a few hours of tests and now the battery charges and the laptop works great. I hope this helps someone:)
Posted on Jan 13, 2013
  • 383 Answers
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Posted on Dec 20, 2007
Why does my kinivo bth220 headphones have a flashing red light on them no matter how long i charge them and they will not turn on
The batteries won't charge. You might want to google around for replacement batteries.
First I'd try a factory reset. PRess the +, - and multifunction button for 6 seconds until the blue light flashes and it shuts off. When you turn them on next, it's in pairing mode and try again.
Aug 10, 2014 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Fan won'tt work and computer wont turn on
Laptop abuse, your luck it will work at all. It sound like it's done. You may have killed it
Nov 04, 2012 | Compaq Presario CQ56-115DX Laptop
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
Why does my gateway nv53 battery light blink while charging?
Hi, The LED light on your Gateway NV53 Blinks while charging because it was designed to do so. According to the user manual, if the battery light is:
Solid Orange: Battery is fully charged Blinking Orange: Battery is charging Blinking Red: Battery is critically low Solid Red: Battery problems, contact Gateway support immediately.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Gateway Computers & Internet
My Gateway computer is plugged in but not charging. The ac adapter is brand new. Why?
Try this- Unplug the laptop, take out the battery, and hold the power button down for 30-45 seconds. After that, put your battery back in, plug in the AC adapter and turn it on. It's usually the solution in your type problem
Apr 18, 2011 | Gateway MX8711 Notebook
I installed Windows 7 on my computer and the battery quit charging after the installation. Does something need to be changed in the computer to help the charging?
No, it's probably just a coincidence that either the battery is "dead" or there is a problem with the motherboard such that the battery is not getting detected/recharged.
Jan 23, 2011 | Gateway MX8711 Notebook
My MX8711 won't power up. The power light doesn't come on, it only flashes red 4 times and then nothing. What does the flashing red light indicate?
It could be realted to your faulty Battery.
Please remove the battery and connect the Power cable. Now switch on the laptop without battery (Make sure Power connector should be connected and switch ON).
Check whether its getting ON now or not.
Sep 25, 2010 | Gateway MX8711 Notebook
My MX8711 is dead....won't,charge power cord is working- Won"t come on and the thing won't charge.Can you help me?
its probably the imput cus even if ur battery isnt taking a charge it should still come on if u have the cord in it
Apr 05, 2010 | Gateway MX8711 Notebook
Gateway MX8711 Notebook Logo
398 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
