Question about Frigidaire ATF6000ES Front Load Washer
Tearing clothing - Frigidaire ATF6000ES Front Load Washer
  • 11,896 Answers
Either use a more gentle cycle or the agitator may be off centered or could have bad coupler or bearings. Otherwise check the seal on top of tub to make sure it is not ripped and catching clothes
Posted on Sep 30, 2009
Electrolux gas dryer snagging clothes
Good Morning Friend,
I understand your Electrolux gas dryer, model# EIGD55HIW, is snagging and tearing your clothes. There is a possibility that the temperature is too high and you are overdrying your clothes. Make sure to dry your clothes on the correct temperatures and correct times. The other possibility is, the finish inside of your dryer has been scratched or chipped. This can cause a snagging or tearing of clothes. To prevent further scratching and chipping of the drum finish, make sure to always remove any foreign objects from pockets before laundering, as well as make sure zippers and fasteners are not hitting the inside of the drum. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIGD55HIW Gas Front Load Dryer...
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
Why is my whirlpool deut washer tearing clothes
Check the little holes around the drum, I have seen pins and needles get stuck in these and cause lots of damage. I would replace the seal.
Apr 10, 2013 | Washing Machines
A wire from a bra is jammed in between the two drums and is tearing clothes. How to you access inbetween the drums. Thank you
remove the heater, if its tearing clothes a piece must be poking through, just pull it out.
Dec 01, 2009 | Dryers
GE front loader keeps tearing clothes
You are overloading if that is all that it happens .....less clothes more water and set the cycle for delicates...... unless the clothes are coming out stuck around the agitator than thats a different prob....
Jul 22, 2009 | GE Washing Machines
Hotpoint Clothes Dryer (ctd00) is tearing clothes.
Hi, It sounds likethe front tub bearing (Glides) might be wore down. To raise the top....... there are two screws located where the door closes to the front panel that hols the top down. Remove those screws and the top should raisse up. Look down toward the front of the drum and see if the glides or felt are ok.
Hope this helps
Vic
May 07, 2009 | Hotpoint Dryers
Can i take apart the drum somthing keeps tearing my clothes
The best access to inside the tub is through the lid/door. Going in through the back will not give you any better access.
If the wire is tearing yur clothes, maybe you can see the end of it poking through a hole. If you can, put a pair of vise grips on the end of the wire and try pulling it back through the hole.
Apr 29, 2009 | Washing Machines
Holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Holes in clothes
Be carefull not to overload and inspect around door and heat entrance area for catch points or sharp areas.
Its usually Washers that tear clothes inspect closly to determin cut or tear. if tear try smaller loads with only similar materials
Dec 31, 2008 | GE DCSR483EA Electric Dryer
Tearing my clothes, putting holes in towels, etc
Call Frigidaire and keep asking for someone higher up until you get results.
Nov 07, 2017 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
