Question about Bissell 8910 ProHeat Clear View Upright Vacuum
I have a bissell carpet steamer and the pump for the suction quit working
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
w
Posted on Sep 30, 2010
Bissell proheat snags on carpet
Hi Richardad229. The front clear window nozzle(s) may be off alignment and can be re-aligned quite easily.
Here's a link to the instructions: http://www.bissell.com/FAQDetail.aspx?id=1212&cid=ccsocial
Apr 20, 2013 | Bissell 1699 ProHeat Clear View Upright...
When I am cleaning carpet, the water spray works
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell 25A3 Upright Vacuum
Bissell carpet steamer not working
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No suction. when i turn it on it cycles water intermittently.
you might need to replace the belts. The pump belt is what cycles the water. Here is a link to the belts you need and the manual:
Bissell Carpet Cleaner Belts and Manual
Dec 09, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Carpet steamer does not **** up the water
take a look at the back side of the suction of the unit. first there's thre ront pies\ce of plastic then there is another. somtimes the secind piece becomes broken and the suction of the unit is wiped out.
Jan 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do you clean the bissell steamer carpet cleaners suction front? cannot get some of the fuss from that front part. Thank you
Take off the 2 screws at the bottom, and it will lift off so you can clean it. Of course this depends on which model number you have.
Apr 18, 2008 | Vacuums
My carpet cleaner
There is a black ovule shaped gasket that sits between the top of the window nooze and the edge of the tank. If it is missing, then you lose suction at that point. Also is the filter on the end of the tank that sits over the square outlet clean?
Mar 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
77 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
