Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
Ventless gas wall heater. Pilot lights but wont stay lit.
When you release the knob to turn on the burners. The pilot goes out. It
goes out no matter how long you hold it. I would appreciate any help I can get
  • 30 Answers
The thermocouple may be worn out.
The thermocouple may have come loose from the valve.
The ODS pilot may be clogged with dust or lint and may need to be cleaned with air(less than 30psi)
The valve or regulator may be faulty.
Posted on Mar 04, 2010
My Delonghi Propane Heater will not stay lit.
this sounds strangely like a safety switch problem , ill bet the device that confirms the pilot lite lit before going to main burner has a problem
Jan 19, 2013 | DeLonghi SafeHeat Heater
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
How do i light the pilot?
Turn the Gas Control Knob inside the heater compartment from OFF to PILOT. Push in the knob and hold it, at the sametime push the ignitor button (will probably be a Red button). Once the pilot lights, continue to hold the Control Knob down for one minute. Then ease off of it. If the pilot stays lit, turn the Control Knob to the ON position. The burner should light, if the Thermostat is set higher than the ambient temperature in the house. If the Ignitor button doesn't work, you can match light the pilot. Just be careful and follow the instructions above, once it's lit.
Hope this helps solve your problem.
Feb 23, 2011 | Williams (5009622) Ceramic Gas Wall...
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
I have what looks to be an old monterey wall-mounted gas heater. the lighting instructions are illegible, and i have never lighted such a unit. i can't even find a model number on it. i need to light the...
look at gas valve, there should be a knob on valve, turn knob to pilot and push button in and hold, the silver tubing coming off valve follow it under the burner, as your holding pilot button down light the endunder burner, if flame appears hold pilpt button down for about a minute then change valve to on and pilot should stay lit, if pilot goes out redo and hold longer, the thermocouple may need to be cleaned.
Oct 27, 2009 | Heating & Cooling
WE can get the pilot light lit but it will not stay on
You will need to check the pressure regulator for the gas.
It sounds like the gas pressure is to low to keep the pilot lit.
John
Oct 01, 2009 | Desa International Blower Glow Warm Wall...
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
1,173 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
