Question about Dual XDVD8181 Car Video Player
Help how do I bypass the e brake wire on a dual xdvd710 without the remote
  • Anonymous Dec 25, 2007
    i just have the dvd player hooked up how do i bypass the parking brake
The parking brake wire is a ground, on the install manuel shows it as a positive. i connected mine to my cig lighter. and just replaced the positive wire feed to the cig lighter with a ground wire feed (directly to the metal frame). so all you have to do is push in the cig lighter to watch videos and pull out the cig lighter to the resting position and the blue screen saver will show with full audio.
Posted on Sep 08, 2008
Just add a valet swich to the ground and the oher to the other end of the brake wire cable
Posted on Dec 23, 2007
Try to bypass a emergeny brake pedal switch for a touch sceen dvd player radio. Its a dual model xdvd710
TRY GROUNDING THE WIRE THAT HAS TO BE HOOK TO THE E BRAKE YOU MAY EVEN HAVE TO GET A SWITCH AN ON AND SWITCH THAT MIGHT WORK EVERY DECK IS NOT THE SAME
Feb 19, 2011 | Dual Electronics XDVD710 Car DVD Player
The emergency brake warning will not go away even when the emergency brake is on...do I need the remote in order to operate the dvd player?
The warning is there because the signal that the brake has been engaged doesn't reach the player - either the unit was badly installed or there's a fault in the wiring. To find which you will have to remove the unit and test the wiring.
BTW you don't need the remote, almost all functions can be easily accessed from the buttons on the unit. The remote is there so that the passengers from the rear seats don't have to lean towards the central console to operate the unit.
Jul 01, 2010 | Dual Electronics XDVD710 Car DVD Player
How do i hook up my parking brake wire on my xdvd710
The yellow/blue wire out the back of the head unit needs to be hooked up to the same wire that is responsible for illuminating the "BRAKE" light on your dash. This tells the DVD player that the car is not in motion. Where this wire is and how to tap into it is entirely dependent on what kind of car you have. You may need to trace the wire out or consult a wiring diagram.
If you wish to bypass this feature (which may be illegal in some states) try this:
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
Feb 26, 2010 | Dual Car Audio & Video
My dual xdvd710 has the emergency brake screen how do i bypass it? what wire coming off the deck would i use.
usualy its red dont mistake it for the ilumination but if you get it ground it.
Feb 05, 2010 | Car Audio & Video
How to bypass a dual xdvd710 without the remote
ground the brake wire from the radio to a switch that cut off and on, to the chassis ground you will have to hit the switch every time you want to watch the tv the switch acts like its hook up to the parking brake so when u hit it twice it thinks that the brake is engage
Oct 09, 2009 | Dual XDVD8170 Car DVD Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 31, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD700
How to get code for xdvd 700
Apr 28, 2008 | Jensen VM9510 Car DVD Player
Dual xdvd710
find the memory wire [yellow] and make sure you connect it right if that isnt the problem check fuse box or make sure your remote is not hooked there
Nov 13, 2007 | Dual XDVD8181 Car Video Player
all you have to do for you to be able to play video while driving is... take the yellow wire with blue strip and wrap it with your ground wire and connect the ground wire to a GOOD chasie ground
Sep 13, 2007 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
516 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
