SOURCE: Wireless adapter in Acer 5610-4610 is gone suddenly
Few ideas here, but obviously these are tricky questions.
Uninstall all software related to the wireless NIC, and then uninstall the hardware in device manager. Shut the machine down. Turn the machine over and remove all the little doors and look to see if the wireless NIC is an add-in card you can access. If it is, remove the retaining screw and remove it. Reboot machine, let it boot up, log in, and then shut down again. Reinstall the wireless card and close everything up again. When you reboot, you *should* get the new hardware found message, if you do, install the with the latest drivers and then reboot, and then check to see if the device is working properly in device manager (no warning messages). If it does not recognize the hardware, check in device manager if it has somehow put it on the unknown device list. If it has, try installing the latest drivers manually for the device by using properties tabs on unknown device in device manager.
If the problem is that the devices won't recognise and install their own drivers, you have a different problem which HP or whomever should solve.
Note, too, that if the laptop included custom control software for wireless connectivity (Intel, I am looking in your direction), the card may not be recognized without it, so install that software again, too.
Hope this helps...
Was a faulty connection of the card to the slot. Guy at the repair point/store where I bought it did a reseat of card and it is fine.
Too bad I didn't try that first before I destroyed all I had set up on hard disk for 5 months...
SOURCE: Gateway 405ROG Wireless Card Driver Problem
Did you try running the driver update tool from Gateway's website? These tools are usually pretty good with finding the drivers for the specific hardware of computers automatically for you:
http://support.gateway.com/support/drivers/search.asp?ref=nofind&ct=fn¶m=gtwupd.exe
