Question about Sewing Machines
I was trying to remove the light bulb from my sewing machine and the bulb came away from the socket, leaving the metal screw-in part behind. I tried using plyers but it appears to be stuck. Can you help me?
  • 208 Answers
Turn the power off and place the machine on it's end so that you can see clearly into the socket.
Bend an L in the pointed end of a nail.
Fill the socket with enough hot glue to securely hold the head of the nail and let it harden. Using pliers, grasp the bent part and push in and turn counter-clockwise.
Posted on Oct 01, 2009
Testimonial: "Thank you it worked great!!!"
How to remove a light bulb cap from overlocker sewing machine
There are two ways to do this Agatha, and I have done it both ways.
TURN THE MACHINE OFF AND REMOVE THE PLUG FROM THE WALL SOCKET!!!
Pull the glass globe of the light from the base. Use a dinner knife to push into the bulb base until it grips, release a little and turn anticlockwise.
OR
Pull the glass globe of the light from the base. Use a pair of needle nose pliers and grip the edge of the base between the jars. Whilst maintaining grip, twist the pliers anticlockwise. This will roll the thin base around the pliers, loosen the base in the fitting and make it very easy to unscrew.
Put a little Vaseline or oil on the new bulb threads and don't overtighten it.
Let me know how you get on Agatha by way of COMMENT below my post.
Jul 10, 2016 | Bernina Sewing Machines
How do I replace light bulbs in a Bernina sewing machine model 1080?
Check the bulb model number old versus new and make sure you have the same number bulb. The bulb number should be on the base of the bulb somewhere. If the bulb has tabs sticking out of the base, check to see that they are placed such that both tabs are on the same plane on the bulb base. Some bulbs have offset tabs that only go in one way to the socket. Try rotating the bulb 180 degrees and insert it again to the socket before trying to rotate it. Check your manual for bulb replacement procedure. Make sure also that you didn't rotate the glass bulb out of its base when you pulled the old one out, leaving the old base still stuck in the bulb socket. If this is the case, unplug the machine and use needle-nose pliers to remove the old bulb base before trying to replace the bulb.
Jan 14, 2015 | Bernina Sewing Machines
How do I replace the light bulb on a Singer sewing machine Athena model 2009 ?
I'm not familiar with this model, but in some machines, the bulb is in a socket underneath the arch. On some machines, you open the side door above the needle mechanism and the bulb is in there.
If you can reach the bulb, depending on the machine, some have a small screw in lamp, just like a regular light bulb, But others use push in bulbs. Typically you remove it by pushing in gently, and turning it as you do so, so it pops out. If one way isn't working, turn the other way. Replace the same way, turning in the other direction.
Nov 19, 2014 | Singer Sewing Machines
Replace light bulb
Make sure power is turned off. Get a pair of pointy nose pliers (may need to try a couple of sizes to get correct one). Use these to get hold of the metal light base and remove. Will probably need to turn base to release.
Jan 18, 2014 | Elna 945 Computerized Sewing Machine
Need to replace light bulb - old bulb broke out but metal part still there
Turn off the power.
There are two base types; screw in and bayonet.
With needle nose pliers try to get hold of the metal base.
If it will not turn (left for loose; right for tight), then it may be the bayonet type base: press in, turn and pull out.
Berninas usually come with a bulb remover. It is a plastic tube about 2" long that everyone wonders..what the heck is this.
Mar 10, 2010 | Bernina Sewing Machines
I have an Elna Super sewing machine that was my mothers. I do not have the manual and need to know how to change the light bulb. Thanks.
I have an Elna TSP (about 35 years old) that I believe is about the same as yours. There is a small hold on the top of the sewing machine (not an oiling hold) near the front. Use the small screw driver that came with the machine and push it down into the hole. The light bulb will be pushed down in back of the needle. The bulb has a bayonet type socket and you have to push up and twist the bulb to remove it. This is not striaght forward and you really need the owners manual to figure it out. If you do not have the original screwdriver, one from an eyeglass repair kit might work. I found your question because I am trying to locate a replacement bulb for my Elna.
Nov 15, 2009 | Sewing Machines
Need to locate a lamp changer for the Pfaff 7570
You my be able to change the light bulb without one. On some versions of the Pfaff 7570, you can remove the left end of the machine to access the bulb socket: remove the top cover that has all the designs pictured on it. Lift the carrying handle. Immediately behind the handle is a hole about 3mm in diameter. Down in that hole, probably too far down to see, there is a phillips head screw. Drop a Phillips head screwdriver into the hole, set it into the screw head and unscrew that screw. This will loosen the left end cap. Pull toward the left to remove this piece and you can access the bulb and socket.
Oct 06, 2009 | PfaFF Creative 7570
I bought a new sewing machine light bulb to replace the one that burned out but can't get it ot screw in the socket. Are all sewing machines bulbs universal?
your bulb part number is X53061020 and no the blubs are not universal I would suggest taking the old bulb with you along with the part number I gave you in order to get the right bulb when you go to the store.
Sep 21, 2009 | Brother LS-1217 Mechanical Sewing Machine
I have a Pfaff 7570 and I would like to adjust the thread tension. Most of the time when embroidering it is set at 1 or 0...and never higher than 3-4. Also I can't get the light bulb end out. it broke...
Lift top cover. remove top cover (flat springs on each end of cover - move one with your finger and top will come off. Lift handle. Look to right of handle end over the head. There is a screw there. LOOSEN screw and front cover will slide away from head. Bunch up a paper towel or napkin and press into broken bulb socket and turn same counter clockwise to get bulb socket out. Good Luck!
Jul 01, 2009 | PfaFF Creative 7570
Cannot get to the lightbulb on an Elna SU sewing machine to chang
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Jan 31, 2009 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
87 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
