Question about Audiovox 8910 Cellular Phone
Its doesn't boot up it goes to audiovox than shuts down showing error fs_dir.c 00652 can this be fixed or it's gone
My Compaq Presario fall down and its screen gone colourless its not show anything normal when boot windows 7 it's colour goes red colour after booting showing very low quality colour....what I
Check the GPU and motherboard are OK by plugging an external monitor into the VGA socket and then booting. If the external screen is OK, replace the LCD screen.
Oct 09, 2014 | Computers & Internet
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
Kyocera FS-C5016N wont power up
the power supply of the printer gone bad, needs to be repair from authorzed service center
Jan 08, 2013 | Kyocera Mita FS-C5016N Printer
Dir-601 doesn't work with windows 8
I don't think it's Windows 8. Connect a ethernet cable fron D-Link to computer. Is your Wireless Adapter Enabled on the computer. Unplug the D-Link, shut down the computer, unplug, remove battery, plug in D-Link , allow it to selftest, plug in computer, boot normally.
Dec 15, 2012 | D-Link DIR601 WirelessN 150 Home Router...
Boot Error Shutting Down Sony NWD-B103F
Contact Sony Tech support via email. they should be able to help. it is free I think.
Jul 14, 2017 | Audio Players & Recorders
My Kyocera FS-1116 MFP says 'printer error'/'engine panic'.
If you get the Engine Panic error message, you need to turn the power switch off and then back on again. If that doesn't fix the error, contact a service representative to help resolve the problem.
Oct 17, 2011 | Kyocera FS-1016 Printer
Acer Aspire One loops on start up screen. All it does is show the acer logo, then shows the ''windows was shut down improperly'' screen with all those options and then goes to the windows xp start up...
Try tapping F8 when the acer window shows, when it shows the muliboot option, scroll down to "Last Known Good Configuration" and hit enter. If it does not boot normally, you will have to get an external dvd drive and boot off the drive with a windows installation disc to perform a repair.
Jan 07, 2010 | Acer Aspire One PC Notebook
Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Sep 25, 2008 | Kyocera FS-1118MFP Laser Printer
"Boot Error, Sutting Down"
You may have let a magnet get near the mp3 player. Go to "My Computer" Then double click on the Mp3 player. You will see "Internal Storage" Icon. Right click it and click format. You will lose all data on the device. Also upgrading to 3.003 does not fix the Boot error problem.
Dec 06, 2007 | RCA Lyra RD2765 MP3 Player
Audiovox 8910 Cellular Phone Logo
52 people viewed this question
Top Audiovox Cell Phones Experts
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
