Question about Garmin GPSMAP-640 GPS Receiver
Can i connect nmea outputs from a raymarine e-80
Is there a way for me to connect NMEA outputs from a Raymarine E-80 Chartplotter to a Garmin GPSMap 640?
    New Friend:
  • 132 Answers
Yes, you need the NMEA out cord set for the E 80 and hook the output of the E series to the input on the power data cord on the Garmin - out to in
Posted on Jan 16, 2010
How do you connect a raymarine dragonfly to the DSC Radio
Although I could be wrong, John it appears to me that there is no NMEA output from the Dragonfly to connect to a DSC radio. Here is the link I checked.
Sorry.
-Steve
Raymarine Dragonfly
Aug 17, 2014 | Raymarine Dragonfly 5.7 Gps/fishfinder...
Is it posible to conect garmin 420s gpsmap to st40 deth transducer
No. St series from Raymarine are made for digital depth only, not fish finding and do not talk nmea. The only way to get that Garmin of yours to see depth would be to go from an ST40 nmea out to that garmin nmea in. Or purchase a nmea 0183 smart sensor and hook it to the garmin.
Apr 08, 2012 | Garmin GPSMAP 420s GPS Receiver
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
I have a SI-TEX black box receiver and I'd like to connect it to a Garmin GPS chartplotter. The SI-TEX black box receiver instructions at one point say:"If the GPS has a NMEA output (or NMEA REF) connect...
Yes, the NMEA- output (I think you lefy uot the "-" in your questoin), anyway, the NMEA - or NMEA negative or NMEA ref is hooked to battery supply ground.
Dont forget to program the Garmin to look for 48,000 baud data.
Jan 10, 2010 | Boating
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
Trying to connect a furuno fcv-585 to a raymarine a-65 via nmea with difficulty !!
Just remember this tip Nmea out + goes to NMEA in + and so on. After that you have to make sure the unit is set up to send those sentences and or receive them. Aside from that it should be pretty easy. However if you hook them up wrong you may blow the port (you won't know that you did it either) No smoke no nothing it just wont pass or receive data.
Nov 27, 2009 | Raymarine NMEA 0183 (E55059)
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
Installation raymarine st6002
The power cable of your 2106 acts as a data cable also. You should find additional unused wires on the cable. Locate the brown and blue wires. You will need to connect the brown wire to the "NMEA OUT +" terminal on the autopilot course computer and connect the blue wire to the "NMEA IN +" terminal on the course computer. Finally, connect the "NMEA OUT -" and the "NMEA IN -" to ground (preferably the same place that the Garmin is grounded (black wire). Be sure that the Garmin interface is set up for NMEA In / NMEA Out. That should get you going!
Feb 20, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine rc435
ripoli, This should site should help you now and in the future: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_alp.php?p_sid=8fkbDBti&p_lva=&p_li=&p_new_search=&p_accessibility=0&p_srch=&p_sort_by=&p_gridsort=&p_row_cnt=696&p_prods=&p_cats=&p_pv=&p_cv=&p_search_type=answers.search_nl&p_nav=foot&p_li=&p_page_head=1&p_page=1&p_page_foot=1 Good Luck, Tim
Feb 05, 2007 | Raymarine NMEA 0183 (E55059)
Garmin GPSMAP-640 GPS Receiver Logo
167 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
