Question about OKI C5200n Laser Printer
OKI C5250 Printer
Everytime I print something it comes out with a crease in the bottom right corner of the paper and the printing smudged in the bottom left corner of each page.
  • OKI Master
  • 1,113 Answers
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Posted on Dec 20, 2007
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
On my oki 5150 the printed paper develops a crease usally in the middle of the page. Usually about 4 inches long, with a small overlap that ends up in a crease ... it's starting to get sufficiently bad so...
If the paper under the crease has print and the fold is "glued down", it is most likely to be a problem with the fuser. Try removing it and look for evidence of warping in the pressure roller. If the fuser looks clean and tidy, go to the other end at check over the paper tray and paper feed mechanisim. It is possible the paper is catching on something at the start of the process. This is most likely if there is print over the crease but not under the fold.
Jan 01, 2018 | OKI C5150n Led Printer
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
Hp 3030 laserjet paper creasing when printing
if the print is also smudged the fuser needs replacing
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
Printer
High moisture content in paper,
or fuser (ie hot bit rear) needs replacement the orange fuser pressure rollers are wrinkled or worn.
Jan 09, 2008 | OKI C3200n Led Printer
Appears to be a roller crease on the paper
i want the installation cd fo my printer HP PSC 1410
Jan 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
Ink
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Sep 27, 2007 | Konica Minolta Magicolor 2530 DL Laser...
Non-printing gap/line down page
Hey Danzo, This error is usually caused by dirt (usually toner) on the laser lens. There should be a cleaner pad somewhere on your machine (though I am not totally familiar with Oki) that will wipe across the lens. If there is no pad, you may have to find access to the lens and wipe it manually with a tissue or similar
Mar 10, 2007 | OKI C5100n Laser Printer
OKI C5200n Laser Printer Logo
611 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
