My asko w6661 washer will fill with water but now will not start agitating. It is about 8 years old but does not see much use since its just the two of us. I recall seeing a motor fault indicator a few days ago but I cycled the power and things went on their way. Now I have no fault indicator but things don't work. Is there a chance that there is a relay gone bad is am I looking at replacing the very expensive motor. I told my wife not to buy this stuff btw but you know how that goes.
Thanks, Johnds
Comments:
Oct 01, 2009
- I took the top off this machine and discovered the drive belt had come off. I took the back off the machine and reinstalled the belt and now life is good for the moment.
We have the Asko W6661 front load washer. we are trying to replace the bearings. how do we do this?...
(More)
We have the Asko W6661 front load washer. we are trying to replace the bearings. how do we do this? and do we need to replace anything else when bearings are replaced (any seals)? Is there an illustration to follow when fixing this machine? thank you for your help.
The panel is faulty - all pixels of the display light up and the machine does not react to any...
(More)
The panel is faulty - all pixels of the display light up and the machine does not react to any button pressed. If a washing cycle is on is continues without a problem - i.e. it most likely is only the display. Anyone an idea - Asko does not provide support in the UK ...
My Asko W6661 washing machine water inlet fault would come on so I check the water inlet line and...
(More)
My Asko W6661 washing machine water inlet fault would come on so I check the water inlet line and filter and everything was ok, but the water still would not come into the machine. I than check the solenoid and found that power was getting to the solenoid but they were stuck closed. I replace the solenoid inlet and now the water does not want to stop. It will start filling the machine with water as soon as I push in the power button even if the door is open and have not push the start button. The solenoids are getting power as soon as I push in the power button. Do I have a faulty main circuit board or is it something else that causing this problem.
I own a ASKO W6661 front load washer and the door will not lock shut. I tried force and pressing...
(More)
I own a ASKO W6661 front load washer and the door will not lock shut. I tried force and pressing hard to the locking locate of the door no luck.
