Question about Roomba Vacuums
I have a 550 that will not **** it drives around and thinks its doing a great job but does not pick up any dirt does anyone know what the problem is or where I can get it fixed ?
  • 101 Answers
Have you cleaned out the dirt compartment? This compartment is very small and fills fast ... Roomba does not have a vacuum in it ... it just sweeps so make sure the brushes are working and in good order ... to test the brushes hold it up and turn it on make sure your fingers are clear of wheels and moving brushes before turning it on. Visually inspect to see if brushes are turning also check for hair and string around wheels and brushes.
dont forget to rate me Thx :) and good luck
Posted on Sep 30, 2009
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
I am using a dirt devil wet dry vac and it is picking up water great but is spraying alot of water out of the top!
Sounds like you are not getting a good seal. Make sure it is locking tight. You may have to use some duct tape! Some have a seal around the top where the cannister is affixed. Check this, may need to get a new rubber seal.
May 22, 2014 | Dirt Devil Vacuums
My roomba 550 goes round and round going know where.all the rest work ok
I have the complete service manual for the 550 series. It is in PDF format and if you would like the complete manual, give me your email address and I will send it to you. Below is the basic cause and repair for your irobot's condition.
Circling at slow, normal or rapid speed:
Most common causes: Dirt has infiltrated the wheel encoder or a drive belt has failed.
In MOST cases, the robot's software will recognize and correct the behavior within minutes. If the battery was recently reset, the robot may act erratic again at startup until the software has a chance to correct the condition. • If the Robot does not resume normal driving behavior within the first couple minutes of runtime, go to DRIVE WHEEL Module inspection and cleaning (Appendix C). If cleaning wheel modules does not correct the problem, both wheel modules may need to be replaced. • Replace drive wheel modules if fixes fail.
Happy Holidays
Dec 16, 2010 | iRobot Roomba 550 Vacuum
Vaccuum will not pick up very much off of the floor
You have a clog in the hose or port going from the brush's to the dirt container. You can blow these out with a compressor. Note: You must seal the end (can use your hand wrapped around it) that you put the compressor hase in. You can also use a more powerfull vacuum that has a exaust on it to do the job.
Apr 15, 2009 | Vacuums
Kenmore vacuum - no suction, brush wont turn
sounds like the vacuum is clogged and putting too much stain on the agitator, so I would clean out the entire passage way for the vacuum and replace the agitator belt, you must clean out all the hoses it is clogged somewhere
Jan 29, 2009 | Kenmore Vacuums
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacuum filter
We bought one a couple years ago too, no filters. Now, WalMart carries replacement filters for other vacuums that will fit. Go back to WalMart and pick up the Durabrand CF2006 - it's in an orange box, works like a champ, I think it was around $5. We bought a couple. Great vacuum.
Aug 26, 2008 | Vacuums
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
370 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
