Question about Canon DR-7580
Canon dr 7580 is not scanning multiple pages.
  • 490 Answers
Check if you have selected 'multipage' option. Then you will get only a single file, but with multiple pages.
If your question is that the second or subsequent pages are not pulled in for scanning, then you need to change the rubber rollers.
S. Mohan
Posted on Jan 09, 2010
Scanning half a page
You will need to check your page settings. As each program is different, the page setup will generally stay the same. It will also change if you are scanning at 0, 90, 180, or 270 degrees as well.
Mar 04, 2014 | Canon DR-7580
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
How to reset counter on canon dr 7580
You need to run Qumatool to reset the counter
S. Mohan
Oct 14, 2011 | Canon DR-7580
My Canon DR 7580 has image void in the front image. Looks like two void columns. The Image reader is clean. Can the upper and lower imager be swapped to see if the problem is the upper imager?
You cannot swap upper and lower images. You can scan the page twice (in duplex mode) by reversing the same. Ensure which side is giving perfect output.
DR 7580 is a CONTACT scanner and hence the paper has to touch the glass surface properly. There are two full sized rollers, just above/below the scanning module, which does this job. Ensure that they are proper and there is enough pressure, press and release 3-4 times to check it is stuck.
S. Mohan, Chennai, India
May 19, 2011 | Canon DR-7580
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
Canon DR-7580 misfeeds intermittantly cutting off about one to two inches of the top section of the page.
Select 'auto detection of page size instead of a fixed size.
S. Mohan, India
Mar 01, 2010 | Canon DR-7580
Canon DR-7580 will scan first 12-14 pages rapidly then pauses, scans a page, pauses, scans a page... I have the exact same scanner hooked to another pc that is exactly the same.. and it flies through the...
Your hard disk must be almost full. Direct the scanning software to send data to a hard Disk location where you have enough space.
S. Mohan, India
Feb 01, 2010 | Canon DR-7580
Canon Dr-7580 not scanning two sided.
Check if you have chosen the 'duplex' option.
S. Mohan
Jan 11, 2010 | Canon DR-7580
Transfer scan settings from one computer to another?
You need to do it only once! Capture perfect remembers the previous setting. If you install Capture perfect in another system it will be only in the defalut mode. You cannot transfer the settings
S. Mohan
Dec 02, 2008 | Canon DR-7580
DR-7580
About 99% of the time, there is something stuck on the lens. Our clients that use these are hard to convince of this, but often if you take a small flashlight, you can either find something stuck on one of the lenses or there's a scratch on one. If it's scratched, you're out of luck and will have to replace it. Otherwise, use a light alcohol based pad and clean with it wrapped around your fingernail. Kodak scanner cleaning supplies work great.
Aug 07, 2008 | Canon DR-7580
391 people viewed this question
old marine
old marine
