Question about Homelite Garden
Need point gap for a super ez automatic - Homelite Garden
    President:
  • 2,220 Answers
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Need to find contact breaker
Hi marie hourig...
Set your gap between .18 and .20...if you do not have a feeler gauge to get the clearance right, then you can use a paper match book cover...it is approximatly the same thickness as you need.
Please take time to rate me
Posted on Sep 13, 2011
What spark plug to use in super xl auto mine doesn't seem to have enough power .
About .030". Remove the muffler if you can and look to see if the piston is all scored up. You may be using garbage gas or mix oil as well.
Jan 01, 2015 | Homelite Super Xl Automatic Chain Saw...
Hooking up wires on ignition coil on a mac-10-10-chainsaw
There are 2 items that you need to pay close attention to is the air gaps;
1. Air gap of the points, and
2. Air gap between the permanent magnet and the pick up coil.
Use the manual to determine the proper gap size.
Good Luck,
Rich Lilja
Jul 22, 2014 | McCulloch 1975 Pro 10-10 Automatic Chain...
Have a farmall super m need gap measurement on the points
The point gap should be 0.013 inches. You should also check the end play and run out on the shaft before point installation (vertical & horizontal movement)- should be minimal or the engine will run erratic or not at all if too loose.
Aug 19, 2013 | Farmall Tractor A-i,av,super A ,super Av...
What is the gap between magneto and flywheel,homelite,super ez chainsaw
0.3mm is a pretty standar air gap for most machines
Dec 11, 2012 | Homelite Garden
Need a manual for homelight textron super ez automatic chainsaw serial # 292740092
You can download then print your Homelite manual by going to www.homelite.com/service/product owners manuals the best way to do it is to right click on the material, left click save, put in in your Documents folder, then retrieve it to print if you actually have to hold paper. Good luck
Sep 23, 2011 | Homelite ZR10926 16 Chain Saw
Need to find contact breaker points gap on super XL automatic chainsaw serial no 50832357 (old chainsaw)
Hi marie hourig...
Sep 13, 2011 | Homelite Garden
I'd like to know what steps to take to replace the contact points on a 1978 Poulan Micro XXV Super Deluxe 14" chain saw
Its a long time since i saw one of these, however, start by removing the starter cover screws and the starter itself, you need to remove the flywheel nut,1/2 spanner as far as i remember, strike the non magnet side of the flywheel with a suitable hammer, the flywheel should just pop off, remove the points back plate cover, this should just pull off, the points and condensor are all one peice, held with two screws, either clean the points or replace the assembly, the back plate will have slots to allow you to set the points gap, the gap is between 12 and 15 thousands of an inch, put a small amount of grease on the felt pad against the cam, refit the flywheel and nut, take care to re fit it onto the woodruff key properly, the air gap between the coil and the flywheel should be set at approx 0.5mm, re fit the starter and check for a spark.
Apr 02, 2011 | Poulan 14" Chainsaw
Point gap setting and timing
sorry my memory is fading. i would gap at 35 and for the timing i used to use a glass of water (sometimes it wasn;t water) put it on the air filter and turn the distributer till it shook the least. of course i had no money ,those days to buy a timing light or manuals....or you might contact/join a old ford club. they are tops for such info...my first car was a ford custom 65......
Jul 23, 2009 | 1999 Ford Super Duty F 450
Garden Logo
298 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
