Question about Sony Ericsson Walkman W810i Cellular Phone
Light at the back of my sony xperia stays on - Sony Ericsson Walkman W810i Cellular Phone
This isnt a how do i. i was wondering if the pre intaled games stay on the Sony Ericsson Xperia play after a hard reset
If the games were loaded as part of the software bundle when new then you will not lose them! Factory reset will only reset back to as new settings!
Sep 23, 2014 | Sony Ericsson Cell Phones
Www sonyericsson com support
It's high time you change its battery boss.
Jul 20, 2014 | Sony Xperia acro S LT26w Unlocked Quad...
Sony xperia troubleshooting
might be its a hardware or software hang. try hard resetting the device if it does not work, visit nearest sony service center
Jul 17, 2014 | Sony Xperia Z1 Black Smartphone - Unlocked...
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA T LT30p
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 | Cell Phones
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  2. Turn on SONY XPERIA S smartphone
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  3. Turn off the SONY XPERIA S
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Dec 19, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
My sony xperia arc lt15i is not work display light
It seems like a display problem you have to change your phone's display
Nov 07, 2013 | Sony Ericsson Xperia Arc Xperia Arc LT15i...
How to go back to Andriod Gingerbread on Sony Ericsson Xperia Neo from Andriod Icecream Sandwich?
i wont to upgrade my sony xperia smartgo wid ice crem gingerbrad can you help me here please
Mar 22, 2013 | Sony Ericsson Xperia Neo
Xperia wont turn on just flashing green light
Hold power button and volume up button at same time. while plugged into a charger.
Mar 03, 2013 | Sony Ericsson XPERIA X10 Cell Phone
Hi i have an experia ant the littli led light on the top stays on red all the time
Hi.
The little red light means your battery requires charging.
Plug in the charger and allow it to charge.
It should change colour to orange when it has over 15% charge in it and then turns green when it is 90% charged.
If it still stays red dispite being fully charged. Try removing the battery for a few seconds and then replace it again.
I hope this helps.
If your phone is fully charged and it still has a red light, then take it back to the shop you acquired it and get a replacement.
It means you have a hardware fault.
Mar 09, 2011 | Sony Ericsson XPERIA X10 Cell Phone
While going through the installation process it seems that the sw does not see the DVD RW drive. What can resolve this issue.
Hi ,
To ensure it's a problem with 321 , go to http://www.dvdfab.com/free.htm and download their free HDDecrypter and see wat happens . I have definitely opted for their products since a wile : just do the job fast and perfect . They have free tools , the rest is 30 days free trial .
Regards .
Jan 17, 2011 | 321studios DVD X Copy Express (200083) for...
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
