Question about Kenmore Elite 45986 Front Load Washer
I have a similiar problem except the code is F35. Can anyone help
I have been getting an F35 code and the water won't run. I have to unplug it to get the door to unlock cuz nothing moves and buttons don't work and door won't unlock when it gets this code. The washer is only 13 months old!
  • 1 more comment
  • patty570 Sep 30, 2009
    I have a Kenmore HE5t Steam King Capacity Washer. Keeps getting the F35 code and nothing will work until I unplug it and try it again.
  • patty570 Oct 01, 2009
    Thank you so much. Someone also mentioned that it could be a pressure switch. Thanks again!
  • rahndee May 11, 2010
    If you open the bottom of the washer there should be like 3 screws holding it in you will find a service manual, look up the F35 code, the manual/cheat book may also be under the top cover (another 3 screws) cant remember where they put them. it could be a pressure switch issue or a fill valve issue or a faulty door lock.
  • 51 Answers
F-35 code is a problem in the pressure switch. the washer thinks its full of water and will not unlock the door replace the pressure switch which is under the top panel and the part # 8181695
Posted on Oct 01, 2009
WHIRLPOOL DUET WASHER MODEL #WFW9600TW01 F-35 & F-28 ERROR
The F35 indicates a water level pressure sensor failure. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. I hope this helps.
also for the F-28 issue
http://fixitnow.com/wp/2011/06/30/how-to-troubleshoot-an-f28-error-code-in-a-whirlpool-duet-sport-washer/
Oct 28, 2014 | Washing Machines
Washer displays F35
F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle. If the tub is empty and you do not see any suds please continue with the following trouble shooting tips. A loose wire harness connection could be causing this problem if there is no water or suds in the tub.
You can order a new analog water level pressure sensor from the Sears PartsDirect website.
Hope this helps.
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
I am getting the code F35. It has happened once in the past and I unplugged it and it rebooted and went through the cycle fine. This time it is not rebooting and won't drain. What does the code mean and...
First remove the service panel and check if junk is in the filter.
This thing works on air pressure rising in the tub from a small tube connected to it.
If that tube has a hole in it or has fallen off the component or has junk in it then the part won't relay the pressure readings to the main control and wreck that freight train.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 03, 2011 | Kenmore HE3T Washer
2 yr old Whirlpool duet washer,suds and now f35 codes. Also when put on cold water i can only get hot water ?
the only reason you would get hot water on the cold setting is if the water lines have been crossed.you can usually clear the cosde by running nothing but clean water through the wash cycle and then use a little less soap.on the next was cycle.unplug the unit for a little bit then wait awhile and run the washer empty.
Nov 17, 2010 | Whirlpool Washing Machines
Trouble code f35
The problem is likely the analog water level switch is failing. A pretty common problem in this machine. Before replace check the hose that goes to it for any blockage. If the hose is not plugged up the switch will need replaacing. Not a cheap part either but easy to replace. It is a small square block with wires and a hose going to it located under the top cover panel. For diagrams and illustrations enter your model # at www.appliancehelponline.com
Jul 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F35 flashing mean? I own a Kenmmore elite front loading washer and besides it being broke down most of time it is pretty but doesn't work most of the time. This week it is flashing F35, I bought...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%&#@
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F35
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
269 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
