Gateway Tabor 3 (4000532) Motherboard Logo
Posted on Sep 30, 2009
I changed the button battery in the motherboard and now it counts the memory up to it's 384mb and stops, giving me a message 'SPD device data missing or inconclusive' I've already reseated memory and putting only one memory stick in at a time to see if any were bad. No Luck!
Will 1gb ddr2 800mhz ram support intel102ggc2
The board has two 240-pin DIMM sockets and supports the following memory features:
  • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • 2 GB maximum total system memory
  • Minimum total system memory: 128 MB
  • Non-ECC DIMMs
  • Serial Presence Detect
  • DDR2 533 or DDR2 400 SDRAM DIMMs
Note
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
Mother board software loading error,SPD missing
Serial presence detect (SPD) refers to a standardized way to automatically access information about a computer memory module. Earlier 72-pin SIMMs included 5 pins which provided 5 bits of parallel presence detect (PPD) data, but the 168-pin DIMM standard changed to a serial presence detect to encode much more information
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
1helpful
Max RAM for Intel 102 GGC motherboard
Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
I wanna know about the compatible ram for my intel d 485 gally mother board with 1.7 ghz processor
  • Suspend to RAM
CAUTION:
Integrator's Notes:
Note:
I hope it helps!!!
1helpful
2answers
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
21helpful
5answers
Olympus VN-3100PC Voice Recorder Problem
I fought with this machine for more than 9 months. And after playing with it today FINALLY got it working.
This is what I did:
Unscrew the faceplate. (Three screws. One is under the batteries).
Put the batteries back on.
Have the HOLD button on the normal position (down)
Press and hold the MENU/FOLDER button together with the STOP button
Press and hold the MENU/FOLDER button together with the DISPLAY button
You will see a GREEN light, then a RED light then a "FOR" message will appear
Press the DISPLAY button and after a few moments it will reset and ask you to enter the time.
GOOD LUCK. Let me know if it works for you.
HAVE A NICE DAY.
Sl-75frv memorys
Dear Sir,
You can install upto 3 GB RAM. i.e. 1GB PC3200 DIMM RAM in each slot.
Please go to BIOS settings & load the defaults. / check following. BIOS settings.
DIMM clock & timing is auto/ detected by SPD (Serial Presence Detect)
Possibly the 1GB RAM you are trying to install does not have SPD / is faulty. Try with a new / working 1 GB RAM.
Hope this helps you friend...
Memory problem
Hi
Compaq Presario 700z notebook PC supports 128MB, 192MB, 256MB, 384MB PC 133 SyncDRAM (SDRAM). The Max Capacity is 384MB.
On this basis, I agree to upgrade the BIOS to support a 133Mhz (PC 133) memory module (DIMM).
At current DIMM capacity and prices, ensure the total memory capacity does no exceed 384MB. On the same note, a 512MB DIMM or two 256MB DIMMs are not supported. The best combination to achieve 384MB will be one 128MB and one 256MB DIMMs.
Compaq Presario 700z notebook PC - Product Specifications - http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00009013&lc=en&cc=us&dlc=en&product=95526&lang=en
Regards
Mike
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
