Question about Poulan Garden
I have to hand choke it in order to keep it running
  • 101 Answers
There are adjusting screws on the carburetor they will be screws with a spring on it ... try slightly adjusting them ... if your choking it then turn the screws out a little this will make it run richer. Btw 1 screw is idle screw the other is high rpm ... looking at the screws the one on the left should be the idle screw ... if you have documentation there may be instructions for this ... good luck
Posted on Sep 30, 2009
Won't idle will run wide open if choked must hold hand on back of carb to start it
Theres a blocked orifice in the carb- Cleaned or not. Check by running thin wire or fish line thru all orifices
Oct 04, 2015 | Motorcycles
Choke must be on to keep running
May just need richening up on the carb screws, there is a special tool to adjust the screws part no, 530035560
Dec 04, 2012 | Husqvarna Hand Held Blower 125 B Grass...
I drive a 1989 Volo 740 2.3L turbo, and while I am driving the engine will die out. If I flutter the gas peddle sometimes I can keep the car going. I changed the fuel filter, the prime pump in the tank,...
Usually- the turbo's wastegate gets stuck from the heat/corrosion. A couple shots of pen oil I recomend PB BLASTER- (non flammable). Actuate the lever manually- with the engine WARM- NOT HOT OR COLD!! If the wastgate is frozen- its plugging and choking the exhaust.
Aug 09, 2011 | 1989 Volvo 740
I have a 1987 dodge ram 50, it has a 2 barrel carb... i cant keep it running i think it is the carburetor because if i wire the choke down it will kinda run, but as soon as the choke is let off it cuts...
The choke is there to cut off the air supply and pull in more fuel when it is cold. You have to repair the choke or put a manual choke on it. the warmer the engine gets , the more the choke opens up.
Feb 11, 2011 | 1987 Dodge Ram 50
Hard to start will run with the choke on dies with choke off
It is the carburator first before you have to take it about squirt some carburator cleaner .take pull the air filter open choke spray cleaner start hold choke in keep spraying in that order sometimes that all it takes to free up some dirt in the gallies and could save you alot of money ,also seafaom is great to put tank as it will clean it internaly couple of cap fulls is all you need good luck
Itsman
Nov 02, 2009 | John Deere Garden
What could be wrong if the engine will not idol?it will run right first thing in the morning but 3minutes later if u don't keep your foot on the gas&brake at a light the engine will shut off. is their...
it just needs the tick over turned up a bit on first start up its still running on choke,,, fast tick over,,,
when the choke comes off it starts to stall on you,,, yes?
the tick over should be set at 750 - 850 rpm (in gear when hot) when makeing any ajustments to the tick over keep the hand brake and foot brake hard on,,,
Oct 30, 2009 | 1990 Ford F150
J.D snowmobile 340 73 carb wont idle appears internally clean.
I would have your compression tested, if its a two stroke, and you can use tools with out breaking things or yourself, pour a cup of fuel down the left hand side of the carb and take the right hand side of the carb off and crank it like mad, if fuel leaks from there you better get to a repairer.
other wise the idle adjuster is usually on the left hand side where the accelerator linkages are, it will be a screw where the linkage touches when the throttle is closed. not too hard to find if you have a light source.
Hope this helps.
If you want any more help just ask :)
Feb 07, 2009 | 1987 Honda NSR 250 MC 16
Garden Logo
48 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
