I have plugged an HDMI cable from my PS3 to my LCD26805HD Acoustic Solution TV, i now have the sound but no image, what can i do to solve that problem ?
5 Suggested Answers
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
SOURCE: my lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
Posted on Aug 21, 2009
  • 58 Answers
SOURCE: invalid format
Use the power button on the front of the console, to put it in standby mode (red light on).
Then press and hold the power button until you hear two beeps.
This should fixya.... :)
please rate this answer!....
Posted on Sep 25, 2009
Testimonial: "thankyou, that actually worked, i did not know this could be fixed this way"
SOURCE: lcd26805hd manual
My acoustic solutions lcd26805hd tv has started flickering really badly every time I switch it on. The flickering goes on for about 30 minutes before it calms down. I have checked all the connections at the back of the tv - all ok. This happens whether I watch cable or a dvd.
Posted on Aug 12, 2010
Tried to hook up ps3 to a different, older tv. was hooked up with hdmi cable and optical audio cable. bought a component cable that works with the ps3. I can't get a picture or sound. or anything else. ...
HDMI is a digital signal, so your TV and your PS3 are basically talking to each other over the connection at all times. That's why when you plug an HDMI connection into your PS3, it can detect the connection and try to switch right to it. Component cables don't work the same way, they only output information, so it's a one way street. Your PS3 is still outputting information, but it still thinks it needs to output to the HDMI port. The fix is pretty simple, and there are two options.
The Long Way
  1. Plug your PS3 into an HDMI TV.
  2. Change the Audio settings first, so your console outputs audio to a Component source.
  3. Now change the Video settings last, so the PS3 is outputting to a Component source as well.
  4. Your screen should go blank once you do this. Hit the X button once, wait a moment, then use the power button on the front of the PS3 and turn it off.
Now just plug the PS3 into the other old TV with the Component cables, and turn it on. You should have picture and sound now.
The Short Way
  1. Leave the PS3 plugged into the old TV, and turn it off with the front power button. Once the light has turned Red, hold the power button down for at least 5 seconds. Don't let go until you should hear the system beep twice.
Now you should be able to use your PS3 on the older TV without a problem.
The Short Way is a simple reset of your video card, it causes the PS3 to revert to outputting to it's out-of-box settings. If neither of these ways worked, check here at the Sony website, and one of those solutions may better fit you, but it sounds like one of the two solutions above should solve it.
Please leave a comment or rating letting me know if this solved your problem, constructive feedback is always welcome. Good luck with your console and good luck with your games.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
Lcd26805hd manual FOR A ACOUSTIC SOLUTIONS LCD TV
Jan 10, 2010 | Televison & Video
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
