Have akia put new power suplly in and have to hit the auto switch for tv to kick on. I have green light and tv is on but can not turn off and buttons do not work.
  • 2 more comments
  • ratedlex Sep 30, 2009
    I got the power supply from hdparts on ebay it cost 179.00. It goes with my model pdp4273m akai 42inch plasma. I will try checking that buttom but i remmber my wife telling me it shocked her finger before it would not come on any more.
    I chcked wires all ar tight.
    the power switch i refer to is on the power supply board it says normal and auto i hit auto it comes on normal it does not come on .
  • ratedlex Oct 01, 2009
    can not find remote and does not respond to buttons on set. it is a pdp4273m akai plasma.
  • 11,896 Answers
The main board may be faulty or there is a bad connection
Posted on Oct 01, 2009
  • Nate Stansfield
    Nate Stansfield Oct 01, 2009
    you can test the capacitors on the main board to see if they are faulty. If the power supply was bad before, the main board may have gotten over power and fried some capacitors
  • 5,138 Answers
What is your Model number?Does TV respond to OFF/ON from Hand unit and can you manual turn TV off?
    President:
  • 1,462 Answers
Pleae check the coonectors running from the Power button to the power supply board, there may be some loose connection
Secondly, have you bought the same model power supply, ie compatible with your TV model and may i know from which place you got, because getting akia tv parts is very difficult to get..
Please leave my query as comment, we may colve your issue
RNJ VINODKUMAR
Posted on Sep 30, 2009
I cant seem to power on
Try pressing and holding the button for a second or two. You may also try using a remote control to power on the tv
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Jan 06, 2015 | Televison & Video
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Mar 20, 2009 | Proview PL926WBi 19" LCD Monitor
I have a never used air conditioner, I put it in window plugged it in, when you hit reset button the green light power indicator comes on, when you hit test it shuts off, the power will not turn on at...
I'm assuming that you're hitting the buttons on the GFI outlet. The test will test the grounding of the outlet. The reset fixes it. These have nothing to do with the A/C. Hit reset and leave it alone.
There is a control panel with fan and temperature switches in the a/c unit somewhere. Turn on the fan/ a/c switch and set the fan on high. Move the temperature switch to mid-range. The noise on the unit should be a bit louder as the compressor kicks in to do the cooling.
Jun 13, 2008 | Samsung Heating & Cooling
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
