Question about Spark Plugs BR4HS Plug 10/BX #3322
Where is the spark plugs on my 2000 kia sportage?
  • 88 Answers
Remove the plastic cover in the middle of the valve cover. You will see the two coil packs and wires. You will need an extension on your plug socket to reach the plugs.
Posted on Jan 30, 2010
What cuases kia sportage spark plug pops out of motor
the plug whole is probably ben bored out to much from it being inserted incorrectly and from re tapping it it might have made it a little to big.
Jun 06, 2012 | 2000 Kia Sportage
How to change plugs on 02 kia sportage
  • 1
    Keep a regular schedule for inspecting the spark plugs on your 2002 Kia Sportage. According to the official 2002 Kia Sportage owner's manual, spark plugs and ignition wires should be inspected every two years or 48,000 miles, whichever comes first.
  • 2
    Let your 2002 Kia Sportage sit for a few hours before opening the engine compartment. You want to make sure that the engine is cool before you begin working on it.
  • 3
    Pop open the hood of your Sportage and locate the ignition wires, which will be attached to the top of your engine. The 2002 Kia Sportage has a four-cylinder engine, meaning there are four spark plugs each attached to an ignition wire. The ignition wires run from the engine to the fuse box, which is located in the left side of the engine compartment.
  • 4
    Inspect the ignition wires of your 2002 Kia Sportage. These wires will need to be replaced if they appear worn.
  • 5
    Disconnect the ignition wire to your spark plugs. Grab the rubber boot located near the base of the wire and pull upward instead of yanking on the wire. Remove only one wire at a time, or mark the wires with a colored Sharpie marker before disconnecting all of them. Improperly reconnecting the ignition wires can seriously affect the performance of your Kia Sportage.
  • 6
    Attach the spark plug socket to your socket wrench. Use the socket wrench to remove the spark plug from the top of the engine's cylinder.
  • 7
    Inspect the spark plug. There will be some soot, but if the spark plug is completely covered in soot, it needs to be replaced.
  • 8
    Position your replacement spark plug in place and secure it with the spark plug socket on your socket wrench. Be careful not to overtighten the spark plug after it has been snuggly fitted.
  • 9
    Position the rubber boot of the proper ignition wire in place above the spark plug and insert it with your hands. Close the hood of your 2002 Kia Sportage
  • Mar 16, 2011 | 2002 Kia Sportage
    How do i change spark plugs on a 2000 kia sportage
    YOU REMOVE THE CYLINDER HEAD COVER.YOU REMOVE SPARK PLUGS FROM TOP OF THE ENGINE CYLINDER HEAD.FIRST YOU REMOVE THE IGNITION COILS AND HIGH TENSION LEADS THEN REMOVE SPARK PLUGS.YOU NEED SPARK PLUGS SOCKET THE LONGER SOCKET WILL BE GOOD YOU NEED LONGER EXTENSION, YOU NEED SPARK PLUGS GAP GAUGE AND A 3/8 RATCHET WRENCH. YOU NEED A TORQUE WRENCH ITS NOT MANDATORT BUT JUST DONT OVER TIGHTEN SPARK PLUGS OR YOU WILL DAMAGE THE ALUMINUM HEAD THREADS.
    Sep 05, 2010 | 2000 Kia Sportage
    Kia sportage 2000 oil like in last spark plug hole
    if in the spark plug hole, then problem could be the valve cover oil seal, that seals the valve cover to the engine, being around 10 years old, this could be the result of the rubber seal hardening up . should not be hard or costly to replace,
    however, if you are referring to you taking the plug out and there is oil in the hole, this could be another matter entirely
    Jun 11, 2010 | 2000 Kia Sportage
    Can't locate the spark plugs on my 2000 KIA Sportage
    SHOULD BE UNDER A COVER ON TOP OF MOTOR
    Dec 20, 2009 | 2000 Kia Sportage
    What is it going to cost me?
    $12. UNLESS you have it done by a shop. Then $120.
    Jun 22, 2009 | 2000 Kia Sportage
    2000 Kia Sportage
    We had o put in two new ignition coils along wit new spark plugs and wires. This solved the problem.
    Oct 16, 2008 | 2000 Kia Sportage
    Spark Plugs BR4HS  Plug 10/BX #3322 Logo
    186 people viewed this question
    Top Ngk Vehicle Parts & Accessories Experts
    Ian Kime
    Ian Kime
    steve morris
    steve morris
    Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
