Question about Garden
How do you change the drive belt on a murray rear engine mower model 30577x8a
  • 437 Answers
You have to remove the deck to get to the drive belt, that is the only way to do it. I would take some notes when I remove the deck to make sure you get it back on all right.
Posted on Sep 30, 2009
Testimonial: "I have the deck off but can't get the belt on the pulley for the trans-axle.Do I have to remove the motor or the trans-axle to get the belt on?"
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How to repair clutch on Murray riding lawn mower 465306X8B
465306X8B - Exploded drive belt parts view.
Jun 26, 2015 | Murray Garden
A drawn illustration of the drive belt on a Murray riding mower?
9f4f0355-fbcc-4309-9d49-c38336c29ea2.gifThis is foe the motion drive on a hydro drive model.
4320ae69-ba36-46cf-8311-f57658515ac0.gifAnd this if the diagram for the deck belt on the same model. Hope it helps
Aug 12, 2014 | Murray Garden
Motor runs fine but can't go foward or backwards on Murray 8hp rear engine riding lawnmower
check the drive belt it might have broke or fell off a pulley
Apr 27, 2012 | Garden
Need a drive belt diagram for a murray lawn mower model 465306x8
Please find attached a "amateur" drawing of the belt routing for the 37x89MA primary deck drive belt. Hope this helps.wefixem.jpg
Mar 03, 2011 | Murray 46 Primary Lawn Mower Blade Belt...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
How do i route the drive belts on my murray riding lawn mower model # 465306X8B
You can download a manual for your Murray here:
Murray manual
This is in .pdf format so you must have Adobe Reader or equivalent available.
FYI: Murray remnants have been bought by Briggs & Stratton so engine parts are no problem, everything else is sketchy.
Aug 25, 2009 | Garden
Murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Jan 17, 2009 | Garden
I have a 12 HP Murray riding mower about 6yrs old model 30577X8A. I am having trouble shifting it in and out of gears, ever thing runs just fine can you help?
Jul 04, 2008 | Computers & Internet
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
