Can I change t-moble Number to the number I want if prior service will not port forward it
    Brigadier General:
  • 3,614 Answers
On this case, you will need to contact your provider for this issue, you have to know if this certain features was available on your service and to the phone.
Hope this initial info helps
Posted on Sep 30, 2009
How can i get rid of this phone number i have on my boist moble l g realm and use my old phone number i have on my metro pcs phone
The phone number is related to the SIM card! So just change the SIM card for the one with the number you want!
Nov 02, 2014 | Cell Phones
Port forwarding instructions
Port forwarding used to forward a port request from wan side to local systems on lan to use specific services provided by servers.
go to Setting, use Port forwarding option. Now click on Add. Enter the Local Ip address of system providing the specific service and then add the starting port number and ending port number, (it may be same). Now click on Save.
Aug 17, 2014 | NetComm Computers & Internet
Trying to port forward a web port, media port, and phone port to an ip address for security camersa
1. Select Port Forwarding/Port Triggering under Advanced in the main menu.
2. From the Service Name list, select the service or game that you will host on your network. If the service does not appear in the list, see the following section, "Adding a Custom Service."
3. In the corresponding Server IP Address fields, enter the last digit of the IP address of your
local computer that will provide this service.
4. To the right of Server IP Address, click Add. The service appears in the list in the screen
To define a service, game, or application that does not appear in the Service Name list, you must first determine which port number or range of numbers is used by the application. You can usually determine this information by contacting the publisher of the application or user groups or newsgroups. When you have the port number information, follow these steps:
2. Click Add Service (see Figure 5-1 on page 5-7).The Ports-Custom Services screen displays.
3. In the Service Name field, enter a descriptive name.
4. In the Service Type field, select the protocol. If you are unsure, select TCP/UDP.
5. In the Starting Port field, enter the beginning port number.
• If the application uses only a single port, enter the same port number in the Ending Port
field.
• If the application uses a range of ports, enter the ending port number of the range in the
Ending Port field.
6. In the Server IP Address field, enter the IP address of your local computer that will provide
this service.
7. Click Apply.
See the rest of the manual here.
http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
Dec 26, 2013 | NetGear WNR2000 Wireless Router
Port Forwarding
Instructions for DG834, DG834G, DG824M, FR114W, FM114P, FR114P, FR328S, FVL328, FVS328, FVS338, FVX538, FWAG114, FWG114P, or FVS318v3 These routers do port forwarding by assigning port numbers to a "service" associated with the application you want to run. "Rules" are set for particular services. Rules block or allow access, based on various conditions such as the time of day and the name of the service. To Create a New Inbound or Outbound Rule 1. Submit the router's address in an Internet browser. (The default is 192.168.0.1). 2. Enter the router's username and password. 3. From the main menu, click Security > Rules. 4. Click Add for inbound or outbound traffic, as appropriate to the application you are planning to run. 5. Select the Service. The services the router knows about are listed in the drop down. If the service you want is not listed, add it as described in the next section. 6. Select the Action, for example ALLOW always. 7. For Send to LAN Server, enter the IP address of the local server. Note that this is also the IP address the computers on your LAN will access. 8. For WAN User choose Any, or limit access to particular IP addresses. 9. For Log selection it is reasonable to turn logs on, especially at the beginning when you are unsure of the result of the changes you are making. Later, you may want to set logs to "Never" for performance reasons. 10. Click Apply. As noted in user manual for some models: * Consider using the Dynamic DNS feature on the Advanced menu, so that external users can find your network when the DHCP lease is renewed by your ISP. * If your own LAN server uses DHCP, and your IPs change on rebooting, consider using the Reserved IP Address feature in the LAN IP menu. To Add a Service for These Routers 1. Click Security > Services > Add Custom Service. 2. Enter any name you choose for the service. 3. Select whether the service is to use TCP or UDP. If you are unsure, select both. 4. Enter the lowest port number used by the service. 5. Enter the highest port number used. If the service uses only one port number, enter the same number. 6. Click Apply.
Feb 19, 2006 | NetGear FWAG114 Wireless Router
Port Forwarding
Feb 19, 2006 | NetGear ProSafe FVX538 Firewall
Port Forwarding
Feb 19, 2006 | NetGear ProSafe FVS328 Firewall
Port Forwarding
Feb 19, 2006 | NetGear FR114P Router
Port Forwarding
Feb 19, 2006 | NetGear FR114W ProSafe 802.11b...
Port Forwarding
Feb 19, 2006 | NetGear DG824M Modem
Port Forwarding
Feb 19, 2006 | NetGear DG834G Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
