Question about Verizon Communications HTC SMT5800 Cell Phone - Silver
Broken screen, need messages out of draft folder
Samsung D900. Screen is a gonner. Got a load of important messages i would like to get off there. What's the dealio?
Have just spent no less than three hours preparing my reply to an email that is clearly of vital importance and all of a sudden it just disappeared off the screen. I desperately need to recover all...
Normallly if you were using an email client you create a mail then the mails would be automatically saved in your draft folder, check out in the draft folder if the email is present and if it is not there in that folder then the mail is lost and there is no way that we can get that back.
Dec 22, 2010 | Computers & Internet
It tells me I have insufficiant memory storage I have deleted txt messages ringtones drafts etc. I have a memory card but it just holds my pictures. It has made me stop recieving text messages and is...
I had the same problem so I called AT&T and they solved the problem!!
1. Click 'Start'
2. Click 'Messaging'
3. Click 'Messages'
You should be in the screen where it shows all your text messages, not just one. If not, click the 'go back' key until you see the list of all your text messages.
4. Click 'Menu'
5. Choose 'Folders'
Your screen should be showing Deleted Items, Drafts, Inbox, Outbox and Sent Items folders.
6. Click 'Drafts' folder
7. Click 'Menu'
8. Choose 'Delete All'
After it has finished deleting, your screen should say To create a new message, etc.....
9. Click 'Menu' again
10. Choose 'Folders' again
11. Click 'Inbox'
12. Click 'Menu'
13. Choose 'Delete All' When its finished deleting it should say 'To create a new message, etc.....'
14. Repeat steps 9-13 for the Outbox and Sent Items folders as well.
15. Once you are SURE you have deleted all your messages in all the folders, click 'Menu', choose 'Folders', and choose the 'Deleted Items' folder
16. Once in the 'Deleted Items' folder, click 'Menu' and choose 'Delete All'
Since the Propel Pro is run by Windows, it's kind of like emptying the Recycle Bin on a computer. You delete the items and they go to a 'Deleted Items' folder, where you can 'Delete All' of the deleted items. I know it sounds confusing, but that is how you can get your 'Free Storage' back.
Once you've deleted your deleted items, (LoL) you can check your 'free storage' by going to "Settings" .. "More" .. "Memory Info" and the "Storage" (middle/orange folder) should have significantly gone down! I went from 89MB to 17MB!!
I really really hope this helps! Good Luck!!
If you still have storage problems, call 1-800-331-0500 and Dial 0 for customer service then dial 1 for technical support. They should be able to help you step by step! I really hope this helped! Good Luck again!!
-Denise
Sep 04, 2010 | Samsung Propel Pro SGH-i627 Cell Phone
Text messages wont send, delete, or change status
I think your mobile is affected by virus. I suggest you to format your memory card and flash your phone. Dont use the backup you have taken other than the contacts. Load other things manually and frehly. hope this helps.!!
Aug 22, 2009 | Samsung Blackjack SGH-I607 Smartphone
Samsung D900 screen broken
You can find the replacement LCD screen for Samsung D900 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/D900
Jun 01, 2009 | Samsung SGH-D900 Cellular Phone
Screen broken
Dear,
how it has broken. if the line are more than normal and is just on casing then u can change the casing but if the lines are in screen itself then u have to change the screen or try to buff a little bit.
try it by the way...
regards,
Feb 23, 2009 | Samsung SGH-D900 Cellular Phone
Problem charging D 900 and opening sim folder
The charging port on your d900 may be broken.
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Jul 14, 2008 | Samsung SGH-D900 Cellular Phone
Samsng D900 broken outer screen
YES THERE ARE SPECIAL TOOLS BUT YOU SHOULD TAKE THE PHONE TO A MOBILE CENTER AND HAVE IT FIX THERE.
Nov 05, 2007 | Samsung SGH-D900 Cellular Phone
Sentbox
press options after typing message and select "save and send". that will save your text messages in the sent itmems folder.
Sep 01, 2007 | Samsung SGH-D900 Cellular Phone
Verizon Communications HTC SMT5800 Cell Phone - Silver Logo
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
