Question about Alarm & Keyless Entry System Dodge Vehicles
I own a Dodge Grand Caravan - the keyless remote appears to have lost battery power. The alarms were acting up just prior to this - with locks being partially activated throughout the van. Finally the alarm system sounded one morning upon entry and would NOT shut off even when keys in the ignition were turned on....although I could not start the vehicle. Do I simply need a new remote battery or is this evidence of larger electrical problems?
  • tjcorwin Sep 30, 2009
    Thank you!
  • 691 Answers
If its serve my memories correctly, the systems you have is that when you remotely activate the alarm system with the key-less remote you must deactivated with the remote also in order for the vehicle to work, the reason why is that if some one break in you car without disarm the car without the main remote the alarm will go off; it keep the thief from starting the car and drive off. the key-less remote system keep the thief from stealing the car by not deactivating the remote first. I hope that make sense to you. you would need to replace a new battery for your remote very doubt would be any electrical problems.
Posted on Sep 30, 2009
Both my keys FOBs on my 2000 Dodge Grand Caravan don't work, changed the batteries, still did not work. Bought 2 new ones and the dealer could not program them.
Programming a Replacement Keyless Entry Remote ' Filear ...
filear.com/?p=131
Oct 17, 2012 - If the transmitters don't work, or if you'd rather not match the transmitters yourself, .... Tried these instructions last night on my 2005 Grand Prix.
Key FOB Not Working - The Chrysler Minivan Fan Club Forums
forum.chryslerminivan.net/showthread.../11859-Key-FOB-Not-Working
Mar 15, 2009 - 10 posts - ‎3 authors
Hi Everyone, One of my Key FOB's stopped working. Is there a way of ... Well, to be honest, you don't know where that FOB has been? LOL ... 2009 Dodge Grand CaravanSXT (3.8L), Light Sandstone Metallic, 125K miles 2005 Volvo .... By jimmy154 in forum 3rd Generation Chrysler Minivans: 1996-2000.
Key May Not Start Car or Release From Ignition : Dodge ...
repairpal.com > Problems > Dodge > Grand Caravan
Dodge Grand Caravan Key May Not Start Car or Release From Ignition. ... If the newkey doesn't work, replacing the lock cylinder including tumblers ... I am able to turn off the van, but the key is stuck in the ACC position, draining my battery. ... In reading other comments, I see it may be the FOB so I'll carry both with me and ...
2009 Dodge Grand Caravan car lock doors not working
Jan 24, 2016 | 2000 Dodge Grand Caravan
I have a 1997 dodge grand caravan and the anti theft locked up and i cant start my van
just cut off power line disconnect alarm power wire or pull out the fuse.
Jun 04, 2014 | 1997 Dodge Grand Caravan
The switch for the power locks no longer works.
Try disconnecting the battery for 10 min and then reconnect it. They did a computer update on my 2005 Caravan and it fixed the problem for a while but now one of the doors does not lock with remote.
Aug 08, 2012 | 2005 Dodge Caravan
I locked my vehicle (2008 Dodge Grand Caravan), with the remote keyless entry fob. The keyless entry will not unlock the doors, even after I replaced the battery. Unfortunately the emergency key that is...
It sounds like your FOB needs to be reprogrammed, email me at bigt_wlm@juno.com around thursday and I will try to email you the programming instructions for that, If I am not able to you will need to call a locksmith with a T-Code or MVP Pro key programmer or DODge to programm your remote to your ECU
Oct 31, 2010 | Dodge Grand Caravan Cars & Trucks
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
My dodge caravan '09 keyless entry does not work at times
I've had the same problem with my 2009 Grand Caravan also.
I asked the dealer about it, but they weren't aware of anything regarding this. Since it has only happened a couple of times during the past year I haven't done anything else about it. They offered to replace the RKE fob (remote) if the problem persisted.
Sep 25, 2009 | Alarm & Keyless Entry System Dodge...
My new 2009 dodge grand caravan keyless remote
RF interference. same bandwidth as there sat communications system. It happens. Hope this helps.
Aug 23, 2009 | Alarm & Keyless Entry System Dodge...
How to disable alarm system
I have 96 dodge caravan and I need to disable the alarm system too and I don't know how!
Apr 20, 2009 | 1996 Dodge Caravan
1996 Dodge Caravan door locks
does it have after market alarm or remote start/ keyless entry system in it? if so that is at fault
Jan 30, 2009 | 2005 Dodge Caravan
New key?
The dealership can use the vin number to make you another key. You shouldn't have to have the keyless remote key. You can get a regular key.
Jan 22, 2009 | 2007 Dodge Grand Caravan SXT Minivan
Alarm & Keyless Entry System Dodge Vehicles Logo
120 people viewed this question
Top SMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
