Question about Home
Whirlpool dishwasher noisy needs new motor - Home
    Genius:
  • 1,036 Answers
You may not need a new motor. If it is "buzzing" it may need a new small run capacitor - that can dry out and fail.
If the pump is noisy (but working) it may need clearing - or if worn - replace the pump.
Only replace the motor if the bearings are badly worn or armature damaged.
Posted on Sep 30, 2009
Noisy Dishwasher
it is a capacitor to start the motor for the next cycle. I think it is inside the door. you may have to call a tech.
May 19, 2013 | Whirlpool GU2300XTVQ Builtin Dishwasher
Dishwasher is now much more noisy when running than it wasbefore.
there may be something down near the impellar wheel of the main wash motor.
if nothing there then you need to check or replace the main wash motor
Apr 13, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
NOISY DISHWASHER WHIRLPOOL GU3600
If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Jul 24, 2009 | Whirlpool GU3600XTS Dishwasher
When i start the dishwasher it will run very noisy and then stops
Sounds like your motor bearing is wornout.Noise is either from Motor bearing or impellor, It will depend on make of Dishwasher. But if it quits after running noisy and over 7years old, get a new one.
Apr 27, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Grinding and Uneven washing
Hi
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Noisy dishwasher
Your motor is makinig all the noise.
Jul 15, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwasher motor is more noisy than it used to be.
Mine does the same thing all kinds of different sounds. This is the 2nd replacement
Jun 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Loud Whining/Humming noise while washing
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Feb 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Home Logo
122 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
