Question about Refrigerators
The drain hole in the freezer keeps freezing solid so ice accumulates on the bottom of the freezer. I have de-thawed it twice but it keeps happening, it is clear after I thaw it out
  • 142 Answers
Either it is slightly blocked or you could try putting a piece of metal wire on the bottom of the defrost heater to act as a heat sink to stop it from over icing.
Posted on Sep 30, 2009
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Water is accumulating & freezing @ bottom of freezer ice maker has been removed water to fridge has been turned off still, water coming from somewhere & freezing
This is what it sounds like to me. There is a drain hole for the defrost water to drain down to the "drip pan" If that hole in the drain pan is clogged. Then when the defrost system melts away the frost in the cooling coils. Every 6 or 8 hours. The water will accumulate in the bottom of the freezer compartment and turn into ice. This is a very common problem.
The solution.
Put the food in the freezer and fridge into coolers and pack with Ice. Get the 99 cent coolers at the supermarket and buy some Ice there too.
Shut the fridge down and open the freezer door. chop out the Ice in the bottom of the freezer compartment, but not in the drain area directly below the coils. that will be hard to get to and you may damage the fridge if you just chop away.
To speed up the process, get some hot water in a glass and pour it into the area below the coils
(that should be a solid block of Ice as well). If you cant get to this easily, just wait for the fridge to thaw out naturally.
After it has thawed out, you should be able to locate the drain tube in the bottom of the small tray
below the coils. Stick a flexible piece of wire, or pipe cleaner or something of the sort into it to completely unclog it. So when you pour water into that tray, it immediately drains out completely.
into the "drain pan" located below the freezer compartment in the base of the fridge.
I hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Maytag MSD2756GES Side by Side...
Fisher and Paykel Fridge/Freezer - Drain Freezing Up
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jul 20, 2010 | Fisher and Paykel Refrigerators
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer drain is full of water and freezes up and water ends up getting on floor. How can it be unplugged?
Remove the food from the freezer and ice maker ( if equipped ) . Remove the screws from the back panel , and remove the panel . Use a hair dryer , starting in the middle , below the coils , and defrost until you see the drain hole . Use hot water to help thaw the drain hole . Once water flows down , use a small hose inserted into the hole , and blow thru , to remove any debris accumulated in the drain line . Get a piece of ALUMINUM solid wire ( 14 - 16 guage ) about 9" long , completely stripped of insulation , and insert it into the hole as far as possible ( without force ) . Wrap the other end , about 1-2 turns around the black rod ( defrost heater ) just above the hole . When the refrig goes into defrost , the heat will transfer to the wire , keeping the drain hole from freezing up again .
Sep 13, 2009 | Whirlpool Refrigerators
Water is accumulating in the refrigerator
Remove the food from the freezer and icemaker (3 screws and a plug hold it in place ) . Remove the screws holding the back panel of the freezer in place , and remove the panel . Using a hair dryer , below the coils , start in the middle , and defrost until you see the drain hole . Keep defrosting the hole , until water starts to drain thru . Use a small piece of hose inserted into the drain , and blow thru it , to clear out any debris accumulated in the drain line . Hot water helps to clear the ice from inside the hole also . To make this a permanent " fix " , get a piece of aluminum solid wire ( 14-16 guage , like an appliance ground wire ) about 8 " long . After the drain is clear , where water runs thru , insert 1 end into the hole as far as it will go without any force , bending slightly if necessary . Wrap the other end around the black tube ( defrost heater )above the hole about 1 - 1 1/2 turns . Whenever the fridge goes into defrost , the heat will transfer to the wire , therfore , keeping ice from blocking the drain again .
Sep 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Drain in fridge is clogged - ice formation under crisper drawers
We have cleared / de-frosted the drain twice and it keeps freezing up, causing the accumulated ice problem to recur. Should the freezer settings be changed?
Aug 13, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Maytag side by side refrigerator ice forms at the bottom of freez
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Jun 02, 2009 | Maytag MSD2454G Side by Side Refrigerator
Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Jan 27, 2009 | Frigidaire FRS20ZSG
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
