Question about Sony Handycam DCR-DVD100 DVD Camcorder
The viewfinder is showing a lime green screen, some colored lines and eventually comes back clear.
  • 125 Answers
The problem is with a view finder cable ,it must have got broken as it gets hard while we using.
Good luck
Posted on Sep 30, 2009
Why did moving green horizontal line appear on screen and won't go away?
hi,
if your cam is equipped with a viewfinder how the picture show, if clear, the LCD is faulty, if in both screens the line appears there may be problem in the circuit, the capacitor on the board must be tested, if it is weak the ripples will appear on screen.
Jan 09, 2016 | Video Cameras
Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Sep 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Vertical green and brown lines on the viewfinder and LCD
Your camera DCR-HC20 has problem with ccd imager and this part will be replaced. After that camera will show live view to record.
Sony announced free of cost repair scheme for such problem. You will pay shipping charges only $15
Click Sony Support for details.
Jan 09, 2008 | Sony DCR-HC20E Mini DV Digital Camcorder
Fuji S2 problem
Err after a shot usually means bad AAA batteries. Change to alcaline or NiMH rechargable.
Dec 27, 2007 | Fuji FinePix S2 Pro Digital Camera
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Rca cc 320
Are the "moire lines" like a wavy, fine pattern that stipes across the screen at an angle? If so, that sounds like an electronics problem. This is caused by the video and audio oscillators mixing together, producing beats which appear on screen. The color, you may can temporarily fix by spinning the right potentiometer, as possibly the beats (to adjust a filter's bandwidth). Without a manual, this may take trial and error, so finding a new camera may be your better bet.
Sep 05, 2006 | RCA CC-439 Camcorder
Sony Handycam DCR-DVD100 DVD Camcorder Logo
116 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
