Mitsubishi Vs-5003r The power will not turn on the TV. It does not produce sound or even the snowy image. Does it have a tube that can be blown? How do I fix it?
  • jmulls Jan 26, 2008
    Mitsubishi vs 5003r won't power on, will only make a clicking noise need to know possible solutions
  • xgator Dec 09, 2008
    Can you please upload a pic or schema for the capacitors or numbers (CXXX) as I cannot find the same capacitors with specs mentioned above?
Change both 47uf 100v caps , both 47uf 50v caps and the 10uf 100v
cap in the primary side of both SMPS transformers. also replace R903 270K
that sometimes opens and the 1k resistor Damon spoke of ,then solder the
heck out of the board. Be careful not to crack any traces from the
components as the traces are very fragile and a mere bump of a component on
the front of the board can cause hours of troubleshooting.
Posted on Jul 24, 2008
Remove screen on Mitsubishi VS-5003R to clean the inside
screen unit is removed from front--remove speaker grill and some screws at bottom of screen and it lifts up and off.
Jun 05, 2012 | Televison & Video
My mitsubishi vs-55707 was smelling burnt and the picture was imbalanced, (an almost 3-D effect) then all color and sound went out. turned it on a few days later, got sound and somewhat of a red tinted...
That would be the CRT Board to Red Tube,Mats Electronics did have some CRT boards $9.95
1-800-628-1118
Encompass Parts Distribution might have them 1-800-638-3328
Jan 14, 2011 | Mitsubishi VS-55707 TV
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv does not come on you can here it sizzle when you push the power button but no sound are picture its a mitsubishi vs-5003r prohection tv
a "sizzle" sound is not ggod especially if you can "Smell" it, I say call a service tech to give an estimate, if you are not electically inclined
Apr 20, 2009 | Televison & Video
Mitsubishi VS-5003R close caption
That is so old I can't find specs on it.If you have a cable box, Directv or Dish Network you can turn on cc from the Receiver box or even an antenna converter box
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi VS-5003R Tuner Out
the tuner is where the cable hooks up on the back of the tv.its out and needs replaced.thats what the message means
Jan 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
No picture or sound
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later, it fixed the intermediate problem of no video, when turning on the power.
Here is a picture of what they look like:
Thank you for using FixYa. Have a nice day and please remember to rate this solution as fbe0a70.png if it helps you.
If you have anymore problems please ask me!
Thanks
Dustin Ellse (BearWeb)
Jul 03, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
