Question about Electric Drills
Why does my drill turn on and off when I tilt it?
Why does my electric drill turn on and off when I tilt it? It never did this before.
    President:
  • 1,489 Answers
If it's a corded drill, the cord is probably broken where it goes into the drill. If it's a cordelss drill, the battery contacts (on the battery or in the battery receptacle on the drill) are loose or dirty.
In other words, when you tilt it the power is shut off to the drill.
If you want more info, let me know.
Charlie
Posted on Sep 30, 2009
Why does it blow controller fuse when key is turned on?
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
fuse keeps blowing Drills & Drill/Drivers Questions ... - Fixyawww.fixya.com > Forum > Tags > fuse keeps blowingDrills & Drill/Drivers fuse keeps blowing questions and answers. Ask your fusekeeps blowing drill and drill/driver questions. Get free help, advice & support for ...Ryobi Multi-Volt Battery Charger Fuse - Questions - Fixyawww.fixya.com > ... > Ryobi > Ryobi Multi-Volt Battery Charger1423701) and have blown the internal fuse. The label on the charger indicates the input is 120V AC. Question about Drills & Drill/Drivers. 1 Answer ...Remember that fuses can fail without showing signs of an obvious ... remember that suspect turn signal flashers, fuses, bulbs and relays can be ... will be predictable, such as a bad current or ground connection, blown fuse and the like. .... The relay then sends power to all the lock motors (all doors except driver's door).Missing: drills
[PDF]Electrical Safety - Occupational Safety and Health ...
https://www.osha.gov/.../4...
Occupational Safety and Health AdministrationShe has an older drill with a steel housing and a 3-prong plug. ... current. This willgenerally allow enough current to flow so that a fuse will blow or a circuit breaker is tripped, thus turning off the electricity in that circuit. ..... There are three major ways tocontrol power line hazards: 1. ... Install warning signs at driver's eye level.Missing: drills ‎key
Jan 07, 2016 | Drills
The Drill has little to moderate use over the last 25 years just developed a problem:
Check the carbon brushes on the back of the motor. It sounds like they are worn or the spring that holds them against the commutator is broken.
Sep 17, 2015 | Speed Drills
Bosch GSB20 2RE will run perfectly through variable range if tilted over to the right. Tilt it to the left and it is as dead as a door nail.
I was going to tell you to check the power cord by the strain relief. Sounds like you got it.
Jan 16, 2013 | Drills
I have an 88 ford 350 and lost the key and it is stuck in off position i am trying to change it but dont know how
First remove the negative battery cable.
It has to be in the LOCK position...
remove the steering wheel.
on tilt wheel applications, remove the upper extension shroud by squeezing it at the top and bottom positions and popping it free of the retaining plate at the right.
remove the 2 trim shroud halves.
disconnect the ignition switch electrical connector.
drill out the break off head bolts connecting the switch to the lock cylinder housing by using a
1/8 in. drill, and remove both bolts.
disengage the ignition switch from the actuator pin.
May 19, 2011 | 1989 Ford Ranger
I ahve a mains powered drill. I have been using it this morning with no trouble. Between changing the drill bits it has developed a problem. The drill will turn on if you tilt it to the sky, but it won't...
Please check your cables terminal for loose and carbon brushes for dirty. It just simple things ( loose contact) in my opinion.
Regards
Mar 06, 2011 | Drills
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
Mar 01, 2011 | Hilti Drills
How to remove key unit from steering column 1986 F150 Ford
COUTESY OF EXPERT "C17HYDRO"
With Key
  1. Disconnect the battery ground.
  2. On tilt columns, remove the upper extension shroud by unsnapping the shroud from the retaining clip at the 9 o'clock position.
  3. Remove the trim shroud halves.
  4. Unplug the wire connector at the key warning switch.
  5. Place the shift lever in PARK and turn the key to ON.
  6. Place a 1/8 in. wire pin in the hole in the casting surrounding the lock cylinder and depress the retaining pin while pulling out on the cylinder.
  7. When installing the cylinder, turn the lock cylinder to the RUN position and depress the retaining pin, then insert the lock cylinder into its housing in the flange casting. Assure that the cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will allow the cylinder retaining pin to extend into the cylinder cast housing hole.
  8. The remainder of installation is the reverse of removal.
This section is for a NON-TILT with no key or non-functioning cylinder:
Fixed Columns
  2. Remove the steering wheel.
  3. Remove the turn signal lever.
  4. Remove the column trim shrouds.
  5. Unbolt the steering column and lower it carefully.
  6. Remove the ignition switch and warning buzzer and pin the switch in the LOCK position.
  7. Remove the turn signal switch.
  8. Remove the snapring and T-bolt nuts that retain the flange casting to the column outer tube.
  9. Remove the flange casting, upper shaft bearing, lock cylinder, ignition switch actuator and the actuator rod by pulling the entire assembly over the end of the steering column shaft.
  10. Remove the lock actuator insert, the T-bolts and the automatic transmission indicator insert, or, with manual transmissions, the key release lever.
  11. Upon reassembly, the following parts must be replaced with new parts:
    • Flange
    • Lock cylinder assembly
    • Steering column lock gear
    • Steering column lock bearing
    • Steering column upper bearing retainer
    • Lock actuator assembly
  1. Assembly is a reversal of the disassembly procedure. It is best to install a new upper bearing. Check that the vehicle starts only in PARK and NEUTRAL.
This section is for TILT and no key or non-functioning cylinder:
Tilt Columns
  2. Remove the steering column shrouds.
  3. Using masking tape, tape the gap between the steering wheel hub and the cover casting. Cover the entire circumference of the casting. Cover the seat and floor area with a drop-cloth.
  4. Pull out the hazard switch and tape it in a downward position.
  5. The lock cylinder retaining pin is located on the outside of the steering column cover casting adjacent to the hazard flasher button.
  6. Tilt the steering column to the full up position and prepunch the lock cylinder retaining pin with a sharp punch.
  7. Using a 1/8 in. drill bit, mounted in a right angle drive drill adapter, drill out the retaining pin, going no deeper than 1/2 in. (12.7mm).
  8. Tilt the column to the full down position. Place a chisel at the base of the ignition lock cylinder cap and using a hammer break away the cap from the lock cylinder.
  9. Using a 3/8 in. drill bit, drill down the center of the ignition lock cylinder key slot about 13/4 in. (44mm), until the lock cylinder breaks loose from the steering column cover casting.
  10. Remove the lock cylinder and the drill shavings.
  11. Remove the steering wheel.
  12. Remove the turn signal lever.
  13. Remove the turn signal switch attaching screws.
  14. Remove the key buzzer attaching screw.
  15. Remove the turn signal switch up and over the end of the column, but don't disconnect the wiring.
  16. Remove the 4 attaching screws from the cover casting and lift the casting over the end of the steering shaft, allowing the turn signal switch to pass through the casting. The removal of the casting cover will expose the upper actuator. Remove the upper actuator.
  17. Remove the drive gear, snapring and washer from the cover casting along with the upper actuator.
  18. Clean all components and replace any that appear damaged or worn.
  19. Installation is the reverse of removal. Check for proper operation.
Nov 23, 2009 | 1986 Ford F150 SuperCab
How to replace ignition lock cylinder on 1984 Ford F-150 pickup?
With Key
Fixed Columns
    • Flange
Tilt Columns
Oct 13, 2009 | 1984 Ford F 150
Delta drill press model DP350 went out while using it
Check for power at the on switch. The switch on this machine should be electrical so yes it could go out. If it is not the electrical type then I would check to make sure that the internal switch did not brake or go bad.
Feb 17, 2009 | Delta Machinery Delta ShopMaster DP350 12"...
Drills Logo
99 people viewed this question
Top Electric Drills Experts
Are you an Electric Drill Expert? Answer questions, earn points and help others
