Back to:
Tags:
Air Conditioners
Generic problem for all Air Conditioners
Blows cold air (by 2 users)
posted by awegman on Dec 19, 2007
package unit heats the house, then when the thermostat reaches the preset temperature it kicks off. when the temperature drops in the house and the furnace kicks back on -- only cold air blows out -- we have to go outside and pull the disconnect, wait a second or two and then plug it back in. By the time you get back in the house it is blowing warm air again. We have woke up several mornings with the house almost the same temperature as outside. Please Help! April in Weston, WV
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Pamela L, posted on Jan 31, 2008
I have the exact same problem. Only I dont' know where the disconnect is outside? My unit is in a mobile home and it is Intertherm system. Bet we have the same system.
Pam
Horner, WV
Best Solution
posted on Dec 20, 2007
Thanks for Trying (70)
fixr1st
Rank:Wiz Wiz
Rating: 83%, 45 votes
Sounds like you have a problem upon start up of heat. Your safteys maybe shutting you down, and restting voltage to your curcuit board allows you to have another heating cycle. Honestly you may due justice calling a tech.
Rating Locked! (?) awegman has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on blows cold air:
I don't want to Accept this solution
Can you Help with these Air Conditioners problems?
Carrier 38CKC036 Air Conditioner
Any recommendations to make Replaceming it go any...
Rinnai RHFE-556WTA Direct Vent Heater NG...
It worked great last year, now this year you turn it on...
Amana PTH153B50AJ Heat Pump, 15000BTU,...
our Amana PTH153B50AJ Heat Pump code light is blinking...
Air Conditioners
how do i replace a honeywell powerhead (40003916)
Air Conditioners
Is it normal for a Dimplex fireplace to click alot when it...
Loading problems.
Repair Service
Find Air Conditioner Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Air Conditioning Contractors
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
