Question about Electric eZip Trailz 26 Women's Comfort Bicycle
The battery couldn't even sustain 5 miles. Please help.
    Scholar:
  • 59 Answers
Many factors need to be taken into account when it comes to Electric bikes and millage. I.E.
A. Battery Condition
B. Weight of Cyclist
C. Terrain (flat, hilly, grass, road...)
D. Tire Pressure
E. Weather (Hot, cold, windy...)
F. Driver
When the manufacture says up to 12 miles per charge. It is probably for:
A. New good condition battery
B. 80lb Girl
C. Flat totally smooth road
D Tires inflated to max pressure
E. Hot day with no wind
F. Someone who drives very gently, and coasts alot.
I know it is totally misleading by the manufacturer. The only thing I can recommend here is max your tire pressure, and look on eBay for a second battery. Oh and accelerate by peddling, this will add much more power to your battery.
Posted on Apr 17, 2010
  • 718 Answers
If your bike has not been used for a long time or you have continuously charged this battery since you bought it the battery is most likely no good anymore. it sounds like the battery is no good. Especially if when you bought it it could run for much more time if the battery is old replace it and only charge the new one when needed and for the specified amount of time. Like your car, batteries do not last forever and this type of battery is under much more load. Batteries plus will fix you up with the correct battery
Posted on Sep 30, 2009
Oldsmobile cutlass ciera
Could be crankshaft sensor.
May 04, 2013 | Cars & Trucks
I problem with the lights on my 192 Buick Lesabre is similar but it oesn't happen all the time. I could drive for 5 mile with the lights on an they will go off, but if i drive another 10 mile and
This is likely a defective main headlight switch, have the switch looked at for signs of heat related damage to the connector, if that is found replace the switch and install a repair connector, both are avail from most parts stores like NAPA and Carquest.
Aug 21, 2012 | 1992 Buick Park Avenue
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
My hp pavilion dv4 laptop's battery cannot sustain even for 1 hour.please give some ideas to maintain the battery and is there any remedy for this issue.Also which is better among, using laptop always...
If the battery appears to be charging, the drop in the time it sustains power is likely due to a faulty or old battery. Eventually it will appear 100% charged and drop to zero in 5 minutes or less. I would think you need to replace the battery.
If you want to maintain the battery properly, it is best to remove it once fully charged and use on ac power alone. If using the laptop on battery, remove the AC connection and allow the battery to fully discharge before recharging it ( there is some debate on this method, other may disagree)
Jul 14, 2011 | Computers & Internet
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
Battery
seriously even the best of batteries only last 3-5 hours without sever deterioration for prolongued and sustained use--thats the battery game and plan for expensive replacement genuine or copy
Feb 21, 2010 | ASUS Eee PC 1000H Laptop
Replaced starter relay, as it met the rules for
You need to have the alternator tested as well. If you have a good battery but a bad alternator, it could take a while for the battery to discharge enough to cause there not to be enough power to engage the starter.
Also check your ground, not just at the battery, but at the engine block as well. Hope this helps/.
Sep 21, 2009 | 1993 Mercury Topaz
My unit just shuts off and will not turn on again until I plug it in as if to recharge the battery. I checked the battery when I first turned it on and it said the battery was fully charged.
Hi there!
It probably does need a battery replacement.
Even though it may show fully charged, and even test as fully charged, it may no longer have the capacity to deliver it for any sustained period.
If you think of a comparison between a 12V car battery, and a 12V alarm battery. Both show full charge, and the same output voltage, the difference is the available plate area. This is reduced due to degredation, and will no longer provide the same output.
Hope this helps.
If you want to make the battery last longer, charge for the recommended time (as was the first charge), then run the battery right down before charging.
If this solves the issue, Please rate as Fixya! thanks.
Jun 20, 2008 | Magellan GPS
Electric eZip Trailz 26 Women's  Comfort Bicycle Logo
191 people viewed this question
Top Electric Cycling Experts
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
