Question about Microwave Ovens
Microwave Oven has died
My Panasonic Microwave Oven NN-E 548C suddenly stopped working - there is no power getting through - no clock, no display, etc. Have checked fuse, which was OK. Have now taken cover off and have found another fuse - it's white and bigger than a normal 13A fuse, with '10A' inscribed on the metal end cap. Below the fuse holder it says:''Hawker 10A Special Fuse''. Can anyone advise whether this fuse is likely to be the cause of the problem and if so, where I can obtain a replacement (in UK)? If not, can anyone please advise what might be the cause of the problem?
Thank you
Archie Westwood
    Genius:
  • 1,036 Answers
Hi.
Check continuity of this 10A fuse to see if it's blown.
What is most likely to have happened, is that an internal short has happened inside the main transformer. These cannot be rectified, and often means scrapping the complete item due to cost of replacement.
However - if you can find another microwave with a different fault - just remove the good transformer.
Checking the transformer for a short at high voltage is not recommended.
You could try a spare 10A fuse as a start point (probably a leaded type) - but expect it to blow again. DON'T go higher or omit !
Posted on Sep 30, 2009
I need model WMS25EGSI manual my microwave does not heat
Posted on Jun 21, 2011
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Jan 11, 2009 | Panasonic NN-S540BF Microwave Oven
Microwave Ovens Logo
293 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
