Question about Nokia 3110 Cellular Phone
My nokia 3110c is not switching on. i checked my batary and changed it too but all in vain. plz help.
SOURCE: nokia 3110c
the code is *#7780# n it will format your mobile ..
Posted on Aug 06, 2008
SOURCE: restart my nokia 3110c automatically
Update your firmware man...
http://translate.google.com/translate?u=http%3A%2F%2Ffirmware.mobilewave.ro%2FNokia-1%2FNokia-3110c-60%2FRM-237-189.html&hl=en&ie=UTF-8&sl=ro&tl=en
Get 6.60 and flash and install...
(go to some mobile shop with the firmware, They will install it.)
Posted on Sep 16, 2008
aledinesh
  • 7 Answers
SOURCE: nokia 3110c drivers
u can dowenload from nokia home page....
of find onn google.....
i ,am sure u will
Posted on Nov 11, 2008
narayanan112
  • 554 Answers
SOURCE: i have changed my Nokia
sir just flash your mobile,
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Posted on Jan 09, 2011
  • 13 Answers
SOURCE: my nokia 3110c is when
follow these steps:
1) remove the back case 2) press the power on button 3) remove the battery (button still pressed) 4) insert the battery (button still pressed)
repeat 2-3 times, this will solve the issue...
if it helps plz vote it
Posted on Jan 17, 2011
Testimonial: "thanx it works,& its really great"
Nokia 3110c 3110c auto restart after 3 mint...
c5 nokia meri mobile 3mint ke bad switch off ho rahi hian phir khud hi open ho jati hian plz plz help me
Dec 07, 2010 | Nokia 3110 Cellular Phone
3110c Cant switch on
it needs to e reprogram.. please vote
Jun 08, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Enter restriction code of nokia 3100 IMEI 355697/00/644546/8
my nokia 3110c needs a restricion code to unlock . what is the code.please help me guys.
Jul 10, 2009 | Nokia 3110 Cellular Phone
Modle no:-3110c phone is restarting itself automatically?
my phone has been locked plz give me un lock code
Jun 29, 2009 | Nokia 3110 Cellular Phone
I FORGET SECURITY CODE OF MY MOBILE NOKIA 3110C AND IMI NO IS 355728022183492 OF MY MOBILE. CAN I RESET SECURITY CODE .PLZ HELP ME
You entered the following IMEI number: 355728022183492 Your Nokia Mastercode: 7651062454rate this fixya
Jun 10, 2009 | Nokia 3110 Cellular Phone
Lock memory card in nokia 3110C
Use memory card unlocker. Its a small device like card reader. You can unlock your card with that.
May 15, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
