How do i set my Rogers 04213 automatic numbering machine to change numbers sequentially instead of randomly as it is currently doing?
  • 3 Answers
I suspect the wheels are sticking together, a common problem from dried ink, or there is a burr or cotton fibber between the wheels. It may be a case of the wrong ink but clean it first. Use a combination of two wooden sticks... most anything will do to hold one wheel while you manually turn the other. Retract the ink pad and lock it back using the catch on the shaft. Use q-tips saturated with kerosean to disolve the ink and lubricate the wheels. If need be you can use a paint scrapper or slim knife to help to spread the space between the wheels after you have let the kerosean do its work. Caution take care to protect your eyes from a snapped blade. It shouldn't take very much force to wedge the wheels apart. If there isnt space on one side rotate the wheels 180 degrees to the other. Although you don't want the kerosean on the ink pad it won't damage anything. You'll want to wipe off, squeeze of, spin off, stamp off as much as possible. as much as possible before you re-ink your pad. Order yourself some Bates numbering machine ink. Take the time to mix it well. My preference is blue if you can get it.
I read where some one had problems with their screws loosening. I never had that problem with this model but if I did I would clean the screws and holes with acetone or solvent quality alcohol and tighten the screws back in with lock tite.
I like to stamp my documents before I scan the for search indexing and he like.
Posted on Oct 20, 2012
2 Suggested Answers
  • 92 Answers
SOURCE: My adler-royal typewriter doesn't type the correct
bad logic
Posted on Aug 29, 2009
How do I manually change the fax number on the Panasonic UF-885 G3?
Follow the steps below and you should be able to change the fax number that is displayed to your recipients.
Press "Function" "7"
Press "1"
Press "Set" until the display reads ID No (your current number)
Press "clear" to erase the current number and enter your desired number
Press "Set" "Stop"
Sep 15, 2014 | Office Equipment & Supplies
I am trying to key text beginning with non-sequential letters/numbers. I cannot make Word quit changing what I key to sequential letters.
I am unsure which version of office you are using. This is a function of auto-correct. You may need to turn it off to stop this behavior, and turn it back on, if you need it to help you compose documents.
( My directions will be using Word 2007, which is what I have installed on my system.)
You need to open the Word Options panel. and go to Proofing.
GO into this location several times in a row, so that you can remember it better, and return to re-enable auto-correct. Uncheck the boxes needed to turn off this behavior.
Mar 19, 2014 | Microsoft Windows Vista Ultimate Edition
A400 sequential numbering
you must go to the menu for the sequential. However is critical that you read VERY WELL your owner manual for to avoid this inconvenience.
God bless you
Jul 31, 2012 | Canon PowerShot A400 Digital Camera
Random 4 digit number on transmission sheet - not dialed number
Update your machine firmware will fix this problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 28, 2011 | Kyocera Mita KM-5035 Printer
I cant figure out how to change the song order when im burning my music to a cd.
When you are writing an MP3 disc the burning software automatically arranges the song sequence by number or alphabetical order. For you to get it in your order just assign numbers in front of the file name so it will go sequentially according to numbers.
Sep 13, 2011 | Audio Players & Recorders
Samsung 5230 - internet connection problem
this was as simple as properly entering the port 80 on the IP address- I should have known better
Dec 30, 2009 | Samsung SGH-S5230 Cell Phone
Every time i put music on it
It is set for random play - go into the menu and change it to sequential play. If you've lost your user manual, you can find it on the Sandisk website, or go here:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Medium changer did not show
Check that the unit is set to random mode instead of sequential mode
(FYI Sequential mode treats the whole machine as a single big tape, while random lets the software say what tape is going to be used.)
Aug 07, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
795 people viewed this question
k24674
jasbo
jasbo
