Slow to start
Wash program slow to start
  • 142 Answers
Poss door lock problem.
Posted on Sep 30, 2009
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
Maytag neptune MAH5500BWQ hot water fill runs slow
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Apr 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag Performa pav2300aww stops and starts
If it's stopping during a wash cycle, suspect the heater elemant not heating up and moving the controller on. See if it runs fine during a spin/drain cycle. If it is very slow on all programs, try the noise filter capacitor before condemning the controller.
May 18, 2012 | Washing Machines
I have a 603k smart drive when I turn the power on at the wall the 5 wash lights show up. When I try to start a wash the short wash, spin,slow and hold lights show up
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 18, 2011 | Fisher and Paykel Washing Machines
My computer is too slow - how do I make it faster?
Slow Start Up
There can be a variety of reasons to Windows loading slow during start up. Go to Run, type msconfig and hit enter. Under the 'Start Up' tab, uncheck the unwanted programs and press OK. Things should be a bit fine the next time Windows boots.
Another program worth mentioning here is StartUp Delayer which will help in setting after how much time programs should be loaded after Windows boots. For instance, you could set your instant messenger program to load 50 seconds after Windows starts up.
Slow Loading Start Menu
If the Start Menu items are loading slowly, you can open the Registry Editor by typing in the Run menu 'regedit.exe' and pressing Enter. Go to HKEY_CURRENT_USERControl PanelDesktop. Look for MenuShowDelay, and double click to edit the value. The lower the number specified, the faster the Start Menu will load.
Slow Right Click Context Menu
Probably the Windows Right Click menu on your computer is loading slow because too many programs added unwanted entries there. Just download this program called Mmm, install it and then modify your context menu to remove unwanted items to speed it up.
win-fixes-send-to.jpg Slow Send To Menu
If the Send To menu loads slowly, you can type 'sendto' in the Run Dialog, and remove unwanted items in the Explorer Window that appears. This should add some speed to it.
Slow Defragmentation
The Windows Defragmenter can't get any slower. You need to have an alternative to the Windows Defragmenter, and Defraggler is just one of the best ones available in the market. It's free, and works like a charm and can speed up defragmentation manifold. For some alternatives, see Five Free Programs to Defragment your PC.
Aug 11, 2011 | Computers & Internet
NEED SETTING WASHING MORE THAN 1HOURS VENUS VW600E WASHING MACHINE
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
The slow inlet flow and clogged draining can slower the time of the wash and so both the inlet and outlet must be cleaned and flushed.
Aug 09, 2011 | Electrolux Washing Machines
Motor turns but very slow
you maybe choose a wool programe it seems to be like that pleas try 1st to select a cotton program
Jun 06, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
COMPUTER STARTS AND RUNS SLOW.. CHANGES PROGRAM VERY SLOW.
some tips:
1. Kill unnecessary programs, you can do it from task manager.
2. some program starts at startup of PC, they make PC slow, go to start>run, type msconfig and say ok, go to startup tab and the disable the programs which you do not want to start up during PC start up.
3. downloan CCCleaner and run it.
4. Keep C drive clean as possible, move as much items to other drive, less space on c drive can slow down you PC.
5. Many files placed on desktop can make it slow.
6. If you have low memory on your PC then you have to increase it.
7. Virus or Spyware can make pc slow do thorough scanning of your PC.
8. I suggest you to uninstall any programs which are not necessary.
all the best.
2667305
Mar 13, 2009 | Dell Microsoft Windows XP Home Edition
Drum speed slow on final spin
what waher is this and what speed is it
Dec 05, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
